Battery questions?
Old Sep 25, 2007 | 02:48 PM
PERFORMANCE RED's Avatar
Default Battery questions?
02 X-type
Needs a new battery. I have been looking at batteries and found that the Duralast and Interstate batteries look exactly like the original Jaguar one, same handles and everything. So I am assuming that Interstate and or Duralast supply Jaguar the batteries with a private label. My guess is Duralast is an Interstate battery labeled for Autozone.
What other options do I have? It seems that batteries for these cars are hard to find. Exide list one but there are no dealers close. What did you replace yours with and what was the cost?
Old Sep 25, 2007 | 05:09 PM
310jag's Avatar
Default RE: Battery questions?
I had trouble finding a battery for mine as well. No luck with Sears, but AutoZone had one in stock that was the right size. It was a Duralast, and normally I try to avoid that brand of parts, but it's held up great over the past 18 months. It was a bit pricey though, at $120.
Old Sep 26, 2007 | 07:46 AM
I got my battery replaced lastnight and not the engine malfunction light is on. Is there something I need to do to reset this? The car run and starts great and all the gauges are reading normal.
Old Sep 26, 2007 | 09:30 AM
tokaygecko's Avatar
Disconnect the negative terminal of the battery, press your brake pedal a few times and let the car sit for a minute or two, the reconnect the battery to see if it goes away. If not, I have no idea what it could be.
Old Sep 26, 2007 | 09:31 AM
tokaygecko's Avatar
ORIGINAL: 310jag
Wow- $120 for a Duralast? Thats expensive. I got a facotry Jaguar battery from Jaguar of Rockville, MD for $124.xx. Definately worth the extra $5 for a factory battery.
Old Sep 28, 2007 | 07:29 AM
ORIGINAL: tokaygecko
ORIGINAL: 310jag
The factory battery is a Duralast/interstate all made by Johnson Controls Inc.
The Duralast has a 3 year replacement and 8 year pro rating. I don't think Jaguar would do that. I also got the 94r-drl, I think that is the number, It has more CCA then the stock battery as well. [8D]
Old Sep 28, 2007 | 11:39 AM
hankycbr's Avatar
I actually put in an original Mercedes battery in my Jag. This mercedes battery is huge and wouldn't fit correctly so I just took off that battery case and so far it works perfectly for almost a year.
Old Sep 28, 2007 | 04:14 PM
hankycbr's Avatar
You have a point. I will make sure my future battery is a better fit. I don't want to mess with the electronics of my car.
Old Sep 29, 2007 | 09:54 AM
jag_genius's Avatar
there is no temperature sensor on the battery box.. that's just a place to plug the plug in.. originally the cars come with a transit relay on the batteryand the connector plugs into it.. keeping certain circuits able to get power. so the battery does not die... while shipping the car.
Old Oct 9, 2007 | 04:28 AM
X2 Jag's Avatar
I paid $120 too @ autozone. Its hard to find these batteries at local autoparts store, unless u special order. I dished out the cash cause I needed the battery ASAP.
Old Oct 9, 2007 | 09:04 AM
aquill1's Avatar
I bought a deca battery...the only place that had a battery to fit and I think I paid either 110-120...worked great for me sine than...As others have said I wouldn't want to increase the battery size or anything just because the electrical systems in these cars are too expensive to fix...
Old Oct 24, 2007 | 09:53 PM
aquill1's Avatar
Glad you got that taken care of...
Forcedair1
Sep 8, 2025 01:57 PM
Dagny
Jun 11, 2024 01:06 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
SeanU
Sep 13, 2015 02:45 PM
DEklof
Sep 8, 2015 05:28 PM
