battery removal=lost radio ?
Old Jan 20, 2009 | 03:00 PM
codafile5's Avatar
Default battery removal=lost radio ?
Hi, I need to change the offside headlight bulb so I need to take the battery off, will I lose the radio coding. I was told that I would'nt ?
Old Jan 20, 2009 | 04:33 PM
JagXV6's Avatar
Default RE: battery removal=lost radio ?
You don't need to remove the battery to replace a headlight bulb on that side. Yes it
is tight, but you don't need to take the battery out. Yes, you will need to have the
radio security code if you disconnect the battery.
Old Jan 20, 2009 | 05:47 PM
Jamey's Avatar
I've disconnected my battery and haven't had to put in the radio code, but keep it close just in case.
Old Jan 20, 2009 | 07:21 PM
bekcon's Avatar
I am the second owner of this car. Where would I find the radio code???
Brian
Old Jan 20, 2009 | 08:04 PM
Dennis's Avatar
ud
Along with your Owners Manual stuff should be a green credit card sized card that has a 4 digit code on it...
But the Dealer can provide you this number also, but from what my Dealer tells me, you must bring the car to them, before they give you the code.
Old Jan 20, 2009 | 08:25 PM
Real_Tech's Avatar
If we are talking about a U.S. spec car and IF the initial inspection and setup was done properly when the car was delivered from the factory to the dealer you will not need the code. Unfortunately many times the inspection and setup are not done properly and the code will be required. You should have the code with your original dealer paperwork. It is also available from the DDW information IF the radio is the original. If the radio has been replaced and you dont have the new code card that would have come with the new radio then it will have to be removed to read the serial number which can then be used to retrieve the code from Alpine. When you ask Jaguar for the code they ask Alpine for the code and then someone tells the owner of the car the code.
Old Jan 20, 2009 | 10:20 PM
MattSteele's Avatar
Real_Tech, what does "the DDW information" mean?
Old Jan 20, 2009 | 10:52 PM
jimmy's Avatar
ud
how does the initial inspection and setup remove the need for a code? Do US cars have a way to bypass the code? I have a code in my owner's manual, and I have had the radio completely removed, and never needed the code. I always found that odd.
Old Jan 21, 2009 | 02:45 AM
Size:  6.3 KBName:  AudiX6JYM-2.jpg
Size:  6.4 KBName:  T15ESSST101-1.jpg
Size:  9.9 KBName:  tshirt03-2.jpg
I believe that codafile is in the UK and pretty much I'd tend to agree with JagXV6.
You dont NEED to remove the battery to replace the headlight as I've had it done without removing the battery. You will however, need a small pair of hands and or some patience.
If you do decide to go down the route of removing the battery I'd say you would definitely need your radio code to hand. If you don't have it your dealer will be able to provide it for you.
Jim
Old Jan 21, 2009 | 04:38 AM
Real_Tech's Avatar
During the initial pre-delivery inspection process there is a step to put the radio in codeless mode and this is supposed to happen for U.S. spec cars but some techs have skipped this step and the code is then needed.
The DDW is Direct Dealer Warranty and is what the dealer prints out when you go in for service. It details all the serial numbers for the various parts installed on your vehicle and lists the start and end dates of the factory warranty, select edition warranty and apco warranty. That's why if the radio has never been changed the code can be retreived by using the DDW rather than removing the radio to get the serial number.
Old Jan 21, 2009 | 06:57 AM
The Chris X's Avatar
Another person here who has had the battery and radio out on multiple occasions with no need for a code.
Also agree that it is not necessary to remove battery box to access headlight. Wear latex gloves while handling the bulb and that way you don't have to be quite as careful when manipulating the new bulb. Small hands would be helpful, but I've got catcher's mitts and can do the job.
philwarner
Oct 4, 2024 01:37 PM
99xk8guy
May 28, 2024 09:36 PM
cissdm
May 3, 2016 06:02 AM
Thang Nguyen
Oct 12, 2015 01:25 AM
jehart49
Sep 12, 2015 05:36 PM
