connecting Iphone4 to my existing audio system
Old Jun 6, 2011 | 10:25 AM
mosahaib's Avatar
Default connecting Iphone4 to my existing audio system
I have an xtype 2003, the audio system installed is the one with single cd no touch screen and no navigation model number 1X43-18B876-CA.
i want to know which is the exact module that i can add to the audio system in order to use the iphone for phone calls and for music, it doesn't have to be a blue tooth one its ok for me to have it connected using wires.
appreciate any helpful information.
Old Jun 6, 2011 | 01:30 PM
Cambo's Avatar
I'm assuming at least that you have the electronic climate control....
But sadly you can't use the OEM equipment for both phone & music functions.
The Jag phone module with bluetooth only works with the phone functions, & the ACM (audio connectivity module) will not allow the phone functionality on an iphone when connected as an ipod.
Check out Jim Rothe's site Adding Accessories (aux in, iPod/iPhone, Bluetooth) to the Jaguar X-Type, S-Type and 2004-2009 XJ he's got the basics covered.
I've retrofitted the OEM Bluetooth into mine, and the music is handled by the ACM, also a retrofit. For the costs involved of fitting these two separate systems, I could have installed a complete aftermarket double-din touchscreen head unit, with Nav, Bluetooth phone, Mp3, DVD input, the lot....
Old Jul 1, 2011 | 08:29 AM
Btfpro's Avatar
Default 2007's seem to have the bluetooth but no Voice Activation
It says in the manual that Voice Activation was an option but I see no record of that in any literature that I have come across.
Old Jul 1, 2011 | 01:21 PM
aluni2230's Avatar
I use the OEM bluetooth + OEM ACM Module with an iphone 4. Works perfectly. I also don't have the navi or touch screen.
Old Jul 5, 2011 | 08:46 AM
mosahaib's Avatar
Thanks for your reply, can you please tell me the models of the OEM Bluetooth and the OEM AC?, or where did you bought them from?
Old Jul 6, 2011 | 10:20 AM
Cambo's Avatar
All available from Jaguar, or if you're lucky from a wrecker....
Latest revision Audio Connectivity Module (ACM) is C2C40513
Bluetooth needs a number of parts depending on what's already installed in your car, my install was done with the following;
Clockwise from the bottom;
Phone module 2W93-19K350-AD (C2C 34515)
Bluetooth Module C2S 38536
D2B Cable for 3x modules, came with the Phone module (secondhand)
Loop to blank off one of the D2B units, came with my ACM
Phone loom 4X43-19A442 from a wrecker
Microphone C2C 29785 LFJ - note that the LFJ refers to the colour, in this case Nimbus Grey
Make sure you're sitting down when you get a quote from Jag!
Since you don't have the touchscreen, you'd probably need to get the phone & maybe the ACM (if you don't have a CD-changer) activated by a dealer or someone with WDS/IDS/SDD.
Have a look at the installation instructions for the phone http://dl.dropbox.com/u/11575086/MOD...othInstall.pdf and for the ACM http://dl.dropbox.com/u/11575086/619...structions.pdf
Old Jul 6, 2011 | 11:54 AM
Dumb/Luck's Avatar
I just took my car to Best Buy and they wired in my iPod directly. I have to use the iPod to control the music, but I can live with that for now. I'd love to have a stock system where I can control the iPod through the stereo, but I'm not about to drop a ton of money for it.
Old Jul 7, 2011 | 02:03 AM
Cambo's Avatar
To be honest I don't use the ipod anymore. The USB stick is better.
Old Nov 11, 2011 | 08:14 AM
mosahaib's Avatar
Default Xtype 2003 key transmitter
My wireless key suddenly stopped working i thought its the battery so i changed it but still not working, does anybody know what else should i check before going to a jag dealer to avoid their cost.
Old Nov 15, 2011 | 03:21 PM
06ProteusWheels's Avatar
How much did this run you over at Best Buy? I'm getting tired of listening to CDs; need my iPod in there!
Old Mar 21, 2012 | 07:55 PM
loulizjag's Avatar
hi guys
i have a 2001 xtype with phone in the center console, navigation screen ad cd changer in the trunk and want to add a bluetooth module to use my phone on the nav screen. i already mounted a mki9000 but it little annoying because of music getting out from only front speakers, gps with no sound when listening to music from phone so now i wanna change and add a bluetooth module if my car can. thanks for telling me what to do
Old Aug 28, 2012 | 03:27 PM
dusty525's Avatar
Hi
I,m new to jaguar ownership and new to this website. Sorry to bring up this Bluetooth problem, but I've read a lot of the posts and the problem I have is I do have the module in the trunk and I do have BT module in the centre console but when I press the phone button I only get " NO PHONE", my iPhone can find the car & although it did pair over the weekend it will not now! The previous owner said that they had the Bluetooth disabled before they brought the car new, I checked with the dealer today and they told me the car left the factory with Bluetooth. Are there any connections behind the audio stack that my have been disconnected just to disable Bluetooth/phone?
Old Mar 12, 2014 | 03:19 PM
Itaiki's Avatar
Hi
Did you ever get this issue fixed? I have the same problem.
Originally Posted by loulizjag
hi guys
trosty
26
Dec 18, 2022 06:40 PM
mbergen
Oct 23, 2019 10:26 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
1100me
Sep 7, 2015 06:26 AM
