crazy sound on bumps
Old Oct 31, 2011 | 02:07 PM
MosDefXType's Avatar
Default crazy sound on bumps
Guys all of a sudden i am hearing a rattling like sound when i drive through, bumpy surfaces. the sound is coming from the rear drivers side. the noise "sounds like i have a metal rim in the trunk that is not secured and it bounces when i drive over bumpy surfaces"
i had all of my shock replaced about 2 months back.
Old Oct 31, 2011 | 02:32 PM
AML's Avatar
AML
Rattling? In the back there is a bushing that the exhaust rests against nearer to the rear differential. One of the sharp edges to the pipe clamp eventually wore down the bushing and it was metal on metal. I would hear a rattle whenever I shut the doors hard, or when the car started, etc. Take a look under and see if you can find when I'm talking about.
When I had my rear control arms replaced, I had the tech grind off that edge so there's no contact anymore.
Old Oct 31, 2011 | 03:04 PM
thanks AML, but i doubt if it is the bushing you mentioned because i don't hear the sound when i close the door nor when i start the car. it is when i drive through bumpy surfaces. could it be the rear control arms?
Old Oct 31, 2011 | 09:14 PM
AML's Avatar
AML
I think the rear control arms is more of a squeaking than a rattling, but I still wouldn't rule it out. Are you getting some extreme camber in the rear wheels?
Old Nov 1, 2011 | 04:01 AM
baffourg's Avatar
check the anti roll bar bushings. They are two in number and they rest on a long metal bar.
Old Nov 1, 2011 | 08:26 AM
pab's Avatar
pab
Also, make sure that your spare tire is screwed down tight.
Jaguar: Grace, Pace, and Space - Sir William Lyons
Old Nov 1, 2011 | 09:08 AM
zoolander's Avatar
A rattiling seems like it could be heat shields...I basically just had to rip all of mine off cause they causing all sorts of annoying rattles....I would start there..just my .02
Old Nov 1, 2011 | 10:56 AM
disguay's Avatar
I would second this. Also called the sway bar. Mine squeaks when I jack it up and whenever my suspension is articulated
JagBrian
Feb 27, 2019 07:08 PM
GordoCatCar
Jan 2, 2017 01:10 PM
ahunt4
Sep 19, 2015 09:49 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Safari
Sep 14, 2015 10:29 AM
