Help Please
Old Sep 16, 2021 | 11:11 PM
domain58's Avatar
Default Help Please
Would some kind member help with the following.
2005 X type 3L auto.
I don't think my car has the cooler plate fitted. It's hard to relate the illustration in the w/s manual to the underside of the car. Could a kind member send me a photo from the underside of their car showing the cooled plate in position. From reading I have done it important to have this cooler plate fitted. part no. c2s18834.
Second request, is there an aftermarket product to use in lieu of the factory sealer that goes under the nut in the output shaft on the T/F case part no. c2s12099. Listed at David Manners and Barratts at 222.85 pounds sterling which is $427.31 plus freight in Aussie dollars. would need to be a world wide brand that we may have in Australia. I think I have a sight leak from this nut.
David Bruce Queensland Australia.
Any replies very much appreciated.
Last edited by GGG; Sep 18, 2021 at 03:13 AM. Reason: Remove personal eMail address
Old Sep 17, 2021 | 08:12 PM
Dell Gailey's Avatar
https://www.jaguarforums.com/forum/x...e-scoop-13356/
member's re-engineering of the scoop from aluminum with pics
https://www.jaguarforums.com/forum/x...t-scoop-15934/
sealer =
https://www.jaguarforums.com/forum/x...12099-a-82832/
Old Sep 18, 2021 | 01:22 AM
domain58's Avatar
Many thanks Dell. I was hoping you would reply because you are such a fountain of knowledge on the X type. I have checked out all the suggested links. A question. I live in a subtropical climate summer temps 25 to 35 deg C. I don't have the cooling scoop and don't know how long it's been missing, car is used as our second car mostly used on club runs 100 to 150 km. Do I need a scoop?
Opinion would be valued.
Kindest regards,
David Bruce.
Old Sep 18, 2021 | 01:36 AM
Well, hhhmmm...
I tore mine off on my trip home to Utah ( over 22 100° F days this summer and 2 months over 90° F) from purchase in NJ in a 5 State blizzard. Never replaced it and yes this would be contrary to the manufacturer's intent. Given that I also don't follow their "sealed for life" guidance, I've elected to renew/replace the fluids to counteract the excessive (?) heat that cooks the fluid to begin with.
Old Sep 18, 2021 | 02:25 AM
domain58's Avatar
Thanks again for the quick reply. I will stress about the cooling scoop. As recommended on this forum I will change he fluids. First job the transfer case oil.
We are so lucky in this day and age to have the internet and helpful and knowledge at the other end of our computer.
Regards,
David Bruce.
Old Sep 18, 2021 | 02:27 AM
domain58's Avatar
Ops typo I meant I will NOT stress about the cooling scoop.
DB.
Old Sep 18, 2021 | 03:24 AM
David,
I've removed your eMail address from post #1. No need to give spammers who trawl the web looking for personal data a helping hand by putting this on a public forum.
If you need to communicate directly with another member, use either a PM (Private Message) or forum eMail. Click on a member's name in any of their posts to open this dialogue box and choose Send a private message to ..... or Send an email to ..... as appropriate. I've used your post as an example here:
Other members can communicate with you directly in the same way. No one can see PM's or forum eMails apart from the sender and recipient(s). Safe and private.
Old Sep 19, 2021 | 02:19 AM
domain58's Avatar
Hi Graham,
Thanks for the advise re email address. I will take it on board.
David Bruce.
Brian D Haas
May 28, 2018 02:01 AM
Old Radar
Apr 19, 2017 06:53 AM
xjsman89
Jul 19, 2016 06:06 AM
ez53436
Feb 22, 2014 08:48 PM
LondonXK8Boy
Jan 19, 2014 05:24 PM
