my retrofit touchscreen vs my doubledin,lots of info
Old Sep 14, 2013 | 08:00 PM
dennis black's Avatar
Default my retrofit touchscreen vs my doubledin,lots of info
well i first installed a doubledin, which was cool it had all the bells and whistle
but then someone tried to break in and take it ,they had no such luck everthing is bolted down,
so now i thought let me try the stock touchsreen sat nav and add movie play back,and a backup camera, usb ETC,
so my first task was to locate all the parts and shematics heres some pic of what i had to get
i posted some of my past projects also
i hope i dont blind you guys with all these pics
what you see is the touch sreen,
harness ,
remote climate controll unit,
dvd rom drive,
gps antenna
optical link
the piece above is the remote climate controll unit the hardest part to get,i got lucky i have 2
it fit perfect in the side
heres some pics of install
started wiring things up
backup camera at night
for the backup camera you tap into our rear light plug the grean and black wire
phone btooth working
heres some of te plugs i orded
heres some of the schematics if you want to try it yourself
this diagram is from dave x thanks bud
look in that mess of wires is the navtool thats what you need to play movies and backup camera of course i straightened up the wiring neatly
heres the button i switch between movies and navigation
heres the audio modulator
this was my double din install youve seen before
WRITE UP TO ADD BACK UP CAMERA AND MOVIES TO SAT NAV
PARTS NEEDED
NAVTOOL i paid $150 on ebay
BACKUP CAMERA i paid $12 ebay
DVD PLAYER i paid $79 for a soundstream one ,i changed the boss one i had
in the diagram all you have to do is cut the four wires in the diagram
on the navtool theres also a acc wire to be hooked up and the backup camera
i made these diagrams to help you guys out when you get the navtool you will see all the wires matchup to my diagram
the diagram they give you is no good , i figured it out for you guys
heres the bluetooth and voice modules connected
heres the harness
running the bluetooth module under the carpet
putting the harness under the carpet is a bitch
PLUS I FOUND SOME M&MS under the console lol
this is what you need for bluetooth and voice intergration
Attached Thumbnails my retrofit touchscreen vs my doubledin,lots of info-20130819_141738_zps488d6485.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130713_121118_zpse5cdff69.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130713_121429_zps2ff149ee.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130914_183608_zps600b73ca.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130914_180107_zps389c8725.jpg
my retrofit touchscreen vs my doubledin,lots of info-20130914_180418_zpse2813ef1.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130913_174921_zps15043354.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130914_164129_zps22cc3ae0.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130914_164222_zpsa0ce9e32.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130909_193336_zps132ebd38.jpg
my retrofit touchscreen vs my doubledin,lots of info-20130909_185444_zps52a3b1cd.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130901_191211_zps8ec626cb.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130901_191133_zpse4fe0583.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130819_141842_zpsddc78f76.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130808_203344_zps66102c87.jpg
my retrofit touchscreen vs my doubledin,lots of info-nav-connectors-2_zpse465fab6.jpg   my retrofit touchscreen vs my doubledin,lots of info-nav-connectors-1_zps083fda2f.jpg   my retrofit touchscreen vs my doubledin,lots of info-x-type-harness_zpsae115f99.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130909_181215_zps0696d0f2.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130901_135108_zps909372ca.jpg
my retrofit touchscreen vs my doubledin,lots of info-20130901_135032_zps3d8d21b5.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130526_212010_zpsf54e9367.jpg   my retrofit touchscreen vs my doubledin,lots of info-scosheinstall012_zps859211c7.jpg   my retrofit touchscreen vs my doubledin,lots of info-4455020.jpg   my retrofit touchscreen vs my doubledin,lots of info-307-1.jpg
my retrofit touchscreen vs my doubledin,lots of info-100_0264-1.jpg   my retrofit touchscreen vs my doubledin,lots of info-015-1.jpg   my retrofit touchscreen vs my doubledin,lots of info-012-3.jpg   my retrofit touchscreen vs my doubledin,lots of info-0092-1.jpg   my retrofit touchscreen vs my doubledin,lots of info-0082-1.jpg
my retrofit touchscreen vs my doubledin,lots of info-001-5.jpg   my retrofit touchscreen vs my doubledin,lots of info-deckz1-1.jpg   my retrofit touchscreen vs my doubledin,lots of info-quad-pipes-b.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130913_211422_zpsa36ab63e.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130915_184552_zps38554766.jpg
my retrofit touchscreen vs my doubledin,lots of info-rgbuni_box_zps46d1e894.jpg   my retrofit touchscreen vs my doubledin,lots of info-camera_zps4a07ad0b.jpg   my retrofit touchscreen vs my doubledin,lots of info-soundstream_zps5f68b13c.jpg   my retrofit touchscreen vs my doubledin,lots of info-pugcolors_zps0b799945.jpg   my retrofit touchscreen vs my doubledin,lots of info-shopwirejpg_zps85bf7b81.jpg
my retrofit touchscreen vs my doubledin,lots of info-20140320_193901_zpst1l3hehh.jpg   my retrofit touchscreen vs my doubledin,lots of info-20140320_193946_zps03hnl0br.jpg   my retrofit touchscreen vs my doubledin,lots of info-20140402_172628_zpsugsekaqv.jpg   my retrofit touchscreen vs my doubledin,lots of info-20140405_132047_zpsix6ppmv9.jpg   my retrofit touchscreen vs my doubledin,lots of info-20140320_194232_zpsqz1op3qf.jpg
Old Sep 15, 2013 | 12:15 PM
Default Some past projects
HERE are some past projects
my rear wheals had bad camber ,so i put a volvo control are ,a tip from thermo thanks
now my wheels are straight
then i had sticking calipers i replaced them and rebuilt the old ones
put quad pipes
did the boot plinth mod thanks to one of the members idea
grille mod
lowering springs
Attached Thumbnails my retrofit touchscreen vs my doubledin,lots of info-20130527_121707_zpsebaa295c.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130527_121716_zps60d8477c.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130527_121745_zpsf3e27814.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130527_122606_zpsf783b69a.jpg   my retrofit touchscreen vs my doubledin,lots of info-20130526_211910_zps8e674f49.jpg
my retrofit touchscreen vs my doubledin,lots of info-100_0091-1.jpg   my retrofit touchscreen vs my doubledin,lots of info-100_0186-1.jpg   my retrofit touchscreen vs my doubledin,lots of info-100_0384.jpg
Old Sep 15, 2013 | 12:20 PM
totalimmortal363's Avatar
The install itself looks wonderful with a lot of thought into the overall look. It's very clean and looks great.
But why the hell use crap BOSS components????? That's a sacrilege in the car audio world
Old Sep 15, 2013 | 05:22 PM
i was trying to find a good player but there was not much to offer i put it in to see if it would work,and bam it worked , and i no what you mean about boss equipment there cheap and like jvc crappy ,so i put it in the trunk and wired it wireless so no one would no lol
now dont tell anyone i have a boss player,
but it gets the job done till i find a quality one,
this is the one going in,now everything works
Attached Thumbnails my retrofit touchscreen vs my doubledin,lots of info-blaupunkpt_zpsecd4b433.jpg
Old Sep 15, 2013 | 06:35 PM
I hear ya on that
Old Sep 16, 2013 | 07:07 PM
Default painted armrest remover cracked one
hid conversion
transfer case fluid change
Attached Thumbnails my retrofit touchscreen vs my doubledin,lots of info-100_0403.jpg   my retrofit touchscreen vs my doubledin,lots of info-transfercase011.jpg   my retrofit touchscreen vs my doubledin,lots of info-transfercase012.jpg   my retrofit touchscreen vs my doubledin,lots of info-paint3_zps1943cbe2.jpg
Old Sep 17, 2013 | 03:53 PM
solidx's Avatar
Need to know how you tapped into the stock screen and added everything. Can you please list parts and details used?
Thanks.
Old Sep 18, 2013 | 07:06 PM
ill add
Old Sep 21, 2013 | 10:18 PM
added write up for adding backup camera and movie play
Old Oct 25, 2013 | 08:37 PM
Attached Thumbnails my retrofit touchscreen vs my doubledin,lots of info-20130727_200831_zpsb00d6a02.jpg
Old Nov 1, 2013 | 12:24 PM
solidx's Avatar
Sweettt!!
Thanks - Awesome Project man! Congrats!
Old Nov 3, 2013 | 03:10 PM
thanks bud,ill be puting in the same thread how to add your android phone on the screen,and have it so its usable ,with internet everthing whats on your phone, i have a samsung gs3 ,
Old Jan 5, 2014 | 05:29 PM
is this the thread your looking for ,nascardad88's
Old Jan 6, 2014 | 04:35 PM
Skinny's Avatar
Wow! How did you change the logo image Dennis?
Old Jan 7, 2014 | 06:48 PM
its fairly easy when you do it ,its temporary you have to go into the diagnostic screen
Old Jan 8, 2014 | 03:43 PM
Skinny's Avatar
The Phone+Menu diagnostic screen? I'd really appreciate it if you could take the time to explain in detail
Old Jan 12, 2014 | 05:20 PM
Default to get daimler logo
to get the daimler log first hold the menu and phone buttons together dont let go untill you see this screen
punch in the code 1971
then you will see this screen
then hit the misc button
you will see this
now hit sytem options ,you will see this
now hit the daimler button then go back
to logo screen
thats it
beware never hit system update or any update you will have a black screen
i hope that helps skinny
Attached Thumbnails my retrofit touchscreen vs my doubledin,lots of info-20140112_150606_zpsb1c8baa9.jpg   my retrofit touchscreen vs my doubledin,lots of info-20140112_150156_zpsa3afb336.jpg   my retrofit touchscreen vs my doubledin,lots of info-20140112_150217_zps60096241.jpg   my retrofit touchscreen vs my doubledin,lots of info-20140112_150358_zpsa7d41664.jpg   my retrofit touchscreen vs my doubledin,lots of info-20140112_150452_zpsc8be6952.jpg
my retrofit touchscreen vs my doubledin,lots of info-20140112_150539_zps4a42e16d.jpg
Old Jan 13, 2014 | 10:15 AM
Skinny's Avatar
Thank you very much Dennis. I've been to the settings menu several times, but using the "917" code. Turns out, it offers other options than "1971." Shame we can't use custom images for the logo screen.
Old Jan 16, 2014 | 08:22 PM
no problem, ill be posting how to get your samsung galaxy 3 or 4 mirrored on the screen
Old Jun 15, 2014 | 05:31 PM
Redhead's Avatar
Sorry Dennis. I don't see the phone module in ur pics. Just touch screen stuuf
