Need help finding part
Old Jan 22, 2012 | 06:16 PM
Freelancer1988's Avatar
Default Need help finding part
I have a 2005 x-type. 3.0 liter. I was wondering if anybody could give me a name to some sort of vacuum line. It is red and plugs into the back of the intake. It is covered though, but it is red. Mine is all crumbled and was wondering what it would cost. Thanks.
Old Jan 22, 2012 | 06:39 PM
*plugs into the back of the upper intake plenum*
Old Jan 22, 2012 | 07:37 PM
here is a picture of where it hooks to on the back of the intake...
Old Jan 23, 2012 | 07:41 AM
and it hooks to some sensor on the other side. (or valve of some sort) I am failing emissions and I just recently replaced the IMT o-rings, the brake booster hose, and inspected the hose from the valve cover to the box. I am getting code P0174 and P0171. I did already search, but this is the last vacuum? line I have left. lol
Old Jan 23, 2012 | 09:20 AM
billbjork's Avatar
FYI-- Look at he picture in the previous post-- see the two black connectors (motors) on the right side. thoughs are motors that run the TUNING TUBES that add 10 hp to the engine. There are "O" rings that dry out and leak tripping P0171/174 codes. Back out the bolts and TRY to pull them out, IF they come out easy they leak, I tweeked mine a bit and there ok, you can spray around them when running to see if they leak as pulling them out all the way might destroy the
"O" rings. There probably BAKELITE so don't pry to hard.
Old Jan 23, 2012 | 11:13 AM
already replaced. The part I'm looking for is the fuel pressure regulator vacuum line I think... Part# C2S28870. Not 100% sure yet.
Old Jan 23, 2012 | 12:53 PM
jimlombardi's Avatar
Hi
The image of a 2004.25 Jaguar X-Type 2.5 & 3.0 is the only thing I could find that might help you find more information about the part you need:
It looks like there might be a cover over it in this image above.
Jim Lombardi
Old Jan 23, 2012 | 08:52 PM
No help, but I appreciate everyone trying. I rolled the dice and ordered the part I listed above. I have a crappy picture from the dealer... so im crossing my fingers.
Old Jan 24, 2012 | 10:37 AM
billbjork's Avatar
Default part find
I talked to Jag and the hose you have circled is a PVC hoss ( not the big one in the front) $7.00. The FUEL PRESSURE REG HOSE they said is part of the plentum $755.00. That is why no picture shows it, if you flip the picture over(or who ever has it) it will show. For $755.00 I would some how find a way to replace a hose. or line or what ever it is. It's called reengineering for the benifit of you wallet. Someone on the forum might have a fix?
Old Jan 25, 2012 | 05:32 PM
xjrguy's Avatar
I think you are safe. What you describe is the vacuum hose from the induction manifold to the fuel injection pressure sensor. Attached is the parts catalogue view.
Good luck!
File Type: pdf
Old Jan 26, 2012 | 09:34 AM
billbjork's Avatar
THANKS XJRGUY The parts dept. told me X-TYPE is the only model that Jag did this to (sold it as a assembly) so unless us mortals have outside info were screwed.
Old Jan 26, 2012 | 04:07 PM
albackuk's Avatar
Hi just email through exactly what you want and i will try to sort it out
we keep a few engines etc that are just for parts so shouldnt be a problem
jaguarxtypeparts@gmail.com
worldwide shipping on most parts no problem
hope this can help you out
Old Apr 3, 2012 | 11:24 PM
DA-X's Avatar
The part # is C2S28870 the package is labled Hose-Vacuum I had the same problem the heat made it brittle and crumpled in my had too. $34
JarodL
Mar 7, 2024 01:39 AM
way2far
Aug 31, 2022 09:26 AM
hafren
Sep 2, 2015 06:22 PM
innzane
Sep 2, 2015 10:08 AM
TC Johnson
Sep 2, 2015 09:30 AM
