Need help Issue with O2 sensor p1647 - Resolved
Old Oct 24, 2012 | 04:12 PM
zibby_uk's Avatar
Unhappy Need help Issue with O2 sensor p1647 - Resolved
Hi
P1647 code came up,
This code is for a front O2 SENSOR
What I have tried:
The he wire connector that is between the battery and radiator, i disconnected it and then switched on ignition and then tested with the multymetre. Incoming Vaults are 8.20volts.
I did the same test for the rear O2 Sensor and in that its the same volts.
I dont understand if theres a problem with the sensor. Can anyone confirm that its not a wiring issue as on both wires its the same valtage with ignition on.
Can anyone advice me on how to sort the problem out and how to go about it.
I dont want to spend lots money and effort and replace O2 SENSOR only for the codes to come back.
I have attached the picture for your better understanding.
the tests i have done so far were they right to do?
Any advice is helpful
Attached Thumbnails Need help Issue with O2 sensor p1647 - Resolved-images.jpg
Old Oct 24, 2012 | 06:09 PM
Ruddigger's Avatar
I just got the same code two days ago. It should be the upstream O2 sensor, under the airbox, if you DO need to replace your sensor the cheapest I found was the Denso 234-9029 on amazon.com
Good luck man.
Old Oct 24, 2012 | 08:54 PM
abonano's Avatar
P1647 has to do with an linear O2 sensor chip - bank 2 - best bet - change out the O2 sensor (www.rockauto.com has good prices as well - Denso is a good choice) Remember to use the forum discount for 5% off...
Old Oct 25, 2012 | 07:31 AM
Poglix's Avatar
Had to replace mine early last year I think, I did write up how to do it at the time, you should find it if you do a search. Front one is easier to do than rear one, I had same code 1647 replacing it and clearing code fixed it. Its still running fine over a year later. The only thing I would say from my own experience, fit a genuine Jag one, I tried a cheaper generic one that I had to fit the connecting plug on, and it failed very quickly and I had to replace it again. Genuine Jag one no problem! Best of luck,
Old Oct 25, 2012 | 04:48 PM
abonano's Avatar
There are many aftermarket O2 sensors that are "plug and play" to the O2 harness - sounds like you purchased a univeral O2 sensor and spliced it in... cheaper yes, but spend the few extra $$$ and get a direct fit O2 sensor.. just my $0.02
Old Oct 25, 2012 | 04:52 PM
Brutal's Avatar
You need a new sensor, the heater element in the sensor is bad(very common) ive done 3 in the past week
Old Oct 25, 2012 | 06:04 PM
+1 to the Upstream HO2 Sensor
However, located in Edinburgh, the recommendations for parts suppliers in the US aren't going to be a cost effective solution for you.
The lowest cost I can find for an OE Jaguar part today (26th Oct 2012) in the UK is from Hatfields Jaguar - Sheffield:
Genuine Jaguar X-Type / XK Upstream Oxygen Sensor | eBay
Old Nov 1, 2012 | 09:41 AM
zibby_uk's Avatar
Thumbs up Quick Update
Quick Update
First removed Oxygen Sensor and tried to clean off carbon and dirt. Fiteed it back but still problem was not solved.
I then bought new Oxygen Sensor from ebay 80pounds and once i fitted it the car is fine and problem solved.
How to replace front Oxygen Sensor:
Disconnect Battery
Release Coolant
Take out Air box
Disconnect Coolant hose
and you will see the sensor in front of you
Thankyou
MrWhite
19
Jun 14, 2022 07:49 PM
JimC64
31
May 30, 2016 03:04 PM
magmedia
Oct 8, 2015 03:28 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
dmatthewman
Sep 30, 2015 10:10 AM
