Need help removing tire of 2002 X-Type
Old Dec 21, 2007 | 10:11 AM
dwclapp's Avatar
Default Need help removing tire of 2002 X-Type
I can't remove the front tire off my 2002 X-Type. I jacked it, removed the 5 lug nugs and the tire turns, so I know it's off the ground, but I can't remove the wheel from thedisc brake rotor.
Any suggestions?
Thanks.
Old Dec 21, 2007 | 10:28 AM
BuckMR2's Avatar
Default RE: Need help removing tire of 2002 X-Type
Use grease on the mating sutfaces before you put the wheel back on and a rubber mallet.
Old Dec 21, 2007 | 02:19 PM
xtyperick's Avatar
Same thing happened to mine when I first got it. Loosen the lug nuts just a small amount with the car not on the jack. Try 1 turn first. Do not take them off so the wheel will fall off, just loosen a little bit. Roll the car a few feet. This should break the rim off the hub.Jack up and remove the tire. As Buck said, use grease when you put the tire back on.
Old Dec 21, 2007 | 03:24 PM
RudyF6's Avatar
Don't mess around. Get a bigazz sledgehammer and a block of wood. Took me about 20 minutes to get the wheels off mine the first time I did it.
Old Dec 21, 2007 | 04:50 PM
somekidzenvy's Avatar
damn you guys did it the hard way. I just used my spare donut as a discus and whacked it off the hub lol took like 4 seconds
Old Dec 21, 2007 | 04:54 PM
310jag's Avatar
My front two wheels were seized like no other the first time I tried to take them off. I've never had a car that was as bad about getting the wheels off as this one is. I thought it was because the car came from up north, but even after cleaning the hubs and greasing them they still give me grief. They're a lot better, but are still more difficult then they should be.
When I put the arubas on I put a lot of work into them. I took them down to bare metal, and lathered them up with white lithium grease.
But as for getting them off, I've had luck with a couple methods;
-Jack the car up, *put it on stands*, and lay on the ground, and bash the wheel with a rubber mallet from behind. If you think of the wheel as a clock, a few goods whacks to the 12, 3, 6, and 9 positions should eventually knock it loose.
-As someone else said, loosen the lug nuts, and with the car on the ground, turn the steering wheel back and forth a few times.
Good luck!
Old Dec 21, 2007 | 08:25 PM
aquill1's Avatar
Hmmm...I'm in michigan with terrible roads and salt but I had no problems...although I don't have the stock alloys...could it be the material in the stockers?
Old Dec 21, 2007 | 10:02 PM
310jag's Avatar
It could be, but I'm not sure. I had some aftermarket wheels on my previous car and never had an issue with them... but then again, I didn't have a problem with the stock alloys that came on it..
Old Dec 22, 2007 | 08:17 AM
RudyF6's Avatar
It stems from a very tight tolerance where the aluminum wheel pilots on the cast iron hub. Mine come off every spring for swap to custom rims. Even with meticulous cleaning of the rim and hub, and a liberal application of anti-seize when they go back on in the fall, it still isn't easy sometimes. Best I can say isI don't have to use a sledgehammer any more!
BTW, Aquill - the custom rims don't fit tight on the hub, so they won't do that.
Old Dec 23, 2007 | 11:29 AM
aquill1's Avatar
Makes sense but why would they have them fit so tight with stock rims?
Old Dec 26, 2007 | 11:29 AM
RudyF6's Avatar
Probably because the OE lug nuts are NOT tapered seat - tight fit for wheel to hub ensures the wheel stays centered on the hub.
Old Dec 26, 2007 | 07:01 PM
aquill1's Avatar
ahhh...
Old Dec 27, 2007 | 07:50 AM
ORIGINAL: aquill1
ahhh...
I see said the blind man....lol
Nice quote there Aquill mate
Jim
way2far
Aug 31, 2022 09:26 AM
cissdm
May 3, 2016 06:02 AM
Dicque
Sep 19, 2015 12:53 PM
avern1
Sep 6, 2015 04:22 PM
Whitnessmouse
Sep 4, 2015 11:09 AM
