New owner need help
Old Dec 22, 2017 | 07:25 PM
Shoprat's Avatar
Default New owner need help
I just bought myself a 2002 jaguar x-type, never owned a jaguar before and I'm in love with it and it's cool features but I unfortunately need help with a electrical problem I can't seem to find a good answer to. So my running lights don't work I've been pulled over by police and it and how it's a hazard driving at night with no running lights, I figured it could be a bad fuse so I go to check the owners manual and this is where I get lost. I have 2 books that came with the car, the driver's handbook supplement book and the driver's handbook, from what I've found online people are saying the fuse for the lights is fuse F62 so I look in both books I just mentioned and they are labeled 2 different fuses, in the driver's handbook supplement F62 is labeled as a mini 7.5 amp brown fuse but in the driver's handbook F62 is labeled as a mini 10 amp red fuse. I'm thinking the books are not for the same jaguar model? Anyway I need advice for the running lights, my lights are not automatic I have to turn a switch to turn on lights when it gets darker out. Thanks in advance
Old Dec 23, 2017 | 01:20 AM
JagV8's Avatar
You can probably get them enabled by a dealer but why would they not already be?
Old Dec 23, 2017 | 02:23 AM
Dell Gailey's Avatar
I'm a bit confused by your term "running lights", U.S. (at least mine) Jags do not normally have DRL's (daytime running lights). On my manual switch (1. low, 2. main, pull once for front fog, once more for rear fog) & then one more setting (3.) if I turn knob one click more is "Automatic" where sensor and car determine when to turn on lights as conditions warrant.
Old Dec 23, 2017 | 02:27 AM
Btw, F62 as posted by you is the rear fog lights fuse.
https://www.jaguarforums.com/forum/x...ram-faq-10712/
Old Dec 23, 2017 | 05:20 AM
PanamaJag's Avatar
I am guessing that your are talking about the front/side/rear parking lights.
Passenger Compartment Fuse Box - (Driver's side dash)
F63 - 7.5 amp mini (Brown) - Right side
F64 - 7.5 amp mini (Brown) - Left side
See attached below for fuses. - Click once to open and click again to zoom in
Old Dec 23, 2017 | 12:28 PM
innzane's Avatar
Have you checked any wire connections? Previous owner may have disconnected them.
Old Dec 24, 2017 | 11:59 AM
Shoprat's Avatar
Ok found the problem, well kinda, I found the correct fuses and they were blown I put in new ones and as soon as I put then in the blew before I could push them in all the way. So now I'm thinking I have a short
Old Dec 24, 2017 | 06:16 PM
PanamaJag's Avatar
Here is an electrical drawing that isolates the wires and connections for the two circuits involved with the parking lights from the fuse box to ground.
Click on drawing once to open it then click on it again to zoom in.
Good luck tracing down the short(s)..
Hope this helps.
Old Dec 25, 2017 | 04:59 PM
innzane's Avatar
People have had issues with the rear lights, the plug/connector melts. Worth checking.
Old Dec 25, 2017 | 06:18 PM
iownme's Avatar
the connections can short out pretty easily.ive had to replace a couple in the past
Old Dec 28, 2017 | 06:20 AM
Shoprat's Avatar
I did kinda look at the connectors when I unplugged the tail lights to replace bulbs thinking that was the problem and the connectors didn't look damaged but I will look again
BadDog42
May 13, 2015 12:23 PM
sjxj6
May 6, 2015 01:32 PM
LadyJag
May 18, 2012 02:10 PM
Elvis87
22
Oct 13, 2010 08:47 PM
voodooskyline
Dec 4, 2007 07:55 PM
