Oil leak on top of engine
Old Aug 8, 2014 | 03:58 PM
foxteca's Avatar
Default Oil leak on top of engine
I am starting to pull off parts to do a tune up and replace my top radiator hose, knock sensor and found what looks to be a sizable oil leak coming from somewhere under the intake manifold and running down the side of the engine and pooling on the transmission. Is there anything other then the valve cover gaskets that could cause that big of an oil leak?
I have attached a pic.
Old Aug 8, 2014 | 05:36 PM
wa3ra's Avatar
A PCV leak could load the intake up, but you'd know about that by the poor running engine and blue smoke. I lay odds on the valve cover gasket
Old Aug 8, 2014 | 05:42 PM
Dr dome's Avatar
I had that on one of my x types. It was the valve cover. Minor issue. Easy fix.
Good luck,
The Dr!
Old Aug 8, 2014 | 05:57 PM
foxteca's Avatar
Good luck,
The Dr!
Good deal. That's what I thought it was but just wanted to make sure there was nothing else I should check.
Old Aug 8, 2014 | 07:12 PM
foxteca's Avatar
Okay so I got the upper and lower intake off and it doesn't look like the oil is coming from the valve cover. It looks like its coming from the base of the cylinder head. Also if it makes any difference the upper and lower intake had a lot of oil in them that came out when I removed them.
Old Aug 8, 2014 | 07:55 PM
Thermo's Avatar
Veteran: Navy
foxteca, I would start with simply applying a little bit of grease remover (Simple Green is a good product that is cheap to use) and then use a hose to wash everything off. From there, drive the car and see where the oil is starting to pool. From there you can get a better idea of where the problem lies. If it is still looking like it is coming from the base of the cylinder head, then you are looking at a bad head gasket where the problem lies with the oil channels, not with the cylinder compression or coolant channels. This can happen.
Oil in the upper and lower plenums is not uncommon, especially if your PCV valve is bad and it is allow too much oil by. Replace the PCV Valve and clean up the plenum too to keep things as clean as you can.
Old Aug 8, 2014 | 09:19 PM
foxteca's Avatar
That's what I'll do. I went ahead and ordered a new pcv value and a set of value cover gaskets because when I went to do the spark plugs after cleaning the intake valley they were full of oil.
Old Aug 19, 2014 | 09:28 PM
foxteca's Avatar
Figured it out. IIt was definitely the valve cover gaskets, the previous owner decided It was easier to just pull the old gaskets out and replace them with black silicone.
Old Aug 21, 2014 | 03:05 PM
Dr dome's Avatar
Sometimes the DR! is right. Well good job on the find, and remember if you need anything just ask.
Ps if you need any parts just pm me what is needed and I will help where I can,
Good luck,
The Dr!
BrentGardner
29
Dec 16, 2024 12:13 AM
Torrid
Feb 15, 2020 08:03 AM
rusty37
Jun 7, 2016 04:43 PM
niner nellie
Sep 1, 2015 10:53 PM
peterg19
Aug 28, 2015 08:42 AM
