Oil pan drain plug size?
Old Oct 10, 2009 | 03:05 PM
MRomanik's Avatar
Veteran: Air Force
Default Oil pan drain plug size?
I tried to do an oil change today. There is a bar just behind the the oil pan that makes it difficult to get to the drain plug.Unfortunately, I now have rounded the drain plug and can't get it off. Anyone know what size the drain plug is? I want to have one on hand before I try again.
Old Oct 10, 2009 | 04:24 PM
Colt's Avatar
Banned
What Bar?..
The drain plug size is a 13MM
Old Oct 10, 2009 | 05:38 PM
MRomanik's Avatar
Veteran: Air Force
I don't what the bar is. Its attached to the frame with 2 bolts on each side. I'll see if I can get a picture. I can't find it in the JTIS or the parts list.
I did a search and found out the drain plug is M12 x 1.75.
Old Oct 10, 2009 | 06:41 PM
MRomanik's Avatar
Veteran: Air Force
Here's a pictur[IMG]file:///C:/Documents%20and%20Settings/Marty%20Romanik/Desktop/Bar.JPG[/IMG]e of the bar
Old Oct 10, 2009 | 07:49 PM
Thermo's Avatar
Veteran: Navy
MRomantik, I am not sure what that bar is, but I would venture to guess that it is aftermarket. TO me it looks like a suspension stiffening piece that is used to tie the two sides of the front frame together. Just to let you know, odds are, that is going to also lead to a big mess when you go to drain the oil as the oil is going to fall on that and splatter everywhere.
Atleast me 03 X-Type does not have that bar. As a side note, you are also missing your scoop for cooling to your transfer case. Not trying to add salt to the wound. Don't worry, a lot of us are missing that scoop. IT is a plastic scoop that if you look at it wrong, it falls off.
Old Oct 10, 2009 | 11:10 PM
MRomanik's Avatar
Veteran: Air Force
Thanks Thermo. I need to take it off to remove the drain plug with a pipe wrench.
I noticed there was not a cooling scoop. I'm not going to worry about that too much.
Old Oct 10, 2009 | 11:21 PM
Colt's Avatar
Banned
Originally Posted by MRomanik
T
You should during the Summer months.
Old Oct 10, 2009 | 11:30 PM
MRomanik's Avatar
Veteran: Air Force
It gets fairly hot here in the summer. Maybe I should look for one.
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
kelliott
May 31, 2022 05:26 PM
Scarecrow
Mar 28, 2016 03:17 AM
Dymaxxion
Sep 4, 2015 02:40 PM
