Oops, i did it again!! customize boot Plinth on a 2004 X-type
Old Feb 26, 2013 | 10:01 PM
mad_mike's Avatar
Default Oops, i did it again!! customize boot Plinth on a 2004 X-type
Just wanted to share an idea i had that made a reality. I went ahead and customized my chrome boot plinth on my 3.0 and wanted to share with you guys. I cut out the "Jaguar" and added an LED light strip in the back. So now my "jag" lights up when i turn on my headlights. Nice challenge, but well worth it!
Attached Thumbnails Oops, i did it again!! customize boot Plinth on a 2004 X-type-back.jpg
Old Feb 26, 2013 | 10:17 PM
b1ghwx's Avatar
I like this! Please share more about how you accomplished this?
Old Feb 26, 2013 | 10:40 PM
mad_mike's Avatar
I didn't take a lot of pix but will upload what i have. I'm not sure if you can do this if you have a 2.5 since the ones i've seen around here have the trunk button on the back part and not underneath the boot plinth. But what i did was remove the chrome part (do this very carefully cause i broke all the screws that hold it to the frame).
I also bought a detail hand saw ( like a mini rotozip at harbor freight only cost me $10! ) i went ahead and drilled into the letters carefully and then grinded out the lined area.
After all the letters were done, i bought an LED white light strip ($39.99) and gorilla glued it to the back.
i tapped into the licence plate light wire ( the right side light ) so when i turn on my headlights, it lights up.
Attached Thumbnails Oops, i did it again!! customize boot Plinth on a 2004 X-type-photo-1s.jpg   Oops, i did it again!! customize boot Plinth on a 2004 X-type-photo-2s.jpg   Oops, i did it again!! customize boot Plinth on a 2004 X-type-photo-3s.jpg   Oops, i did it again!! customize boot Plinth on a 2004 X-type-photo-4s.jpg
Old Feb 27, 2013 | 12:35 AM
exexpat's Avatar
Golf clap. Well played.
Old Feb 27, 2013 | 02:36 AM
DavidN's Avatar
I thought about pinstriping the recessed letters with black varnish on my X-Type.
(I have the sports model with a color matching boot lid finisher.)
But this idea is simply AWESOME !!!
Old Feb 27, 2013 | 08:16 AM
Alfadude's Avatar
That has to be the nicest mod I have seen anyone come up with in quite a while. Nice imagination and nicely executed.
Old Feb 27, 2013 | 09:42 AM
Lcgi's Avatar
Looks really good.... well done Mate.
For the 2.5 model (centre boot switch) I wonder how fluorescent paint would
go - in lieu of the LED's
Old Feb 27, 2013 | 10:47 AM
Bruce in North Dakota's Avatar
From: That Rectangular Hole in the Consciousness of America
I think Alfadude said it best, and I totally concur.
It makes me want to grab my Dremel Tool grinder and run out to the Jag right now.
What I find most attractive about your mod is that it is so "seriously understated". The folks on the Jaguar Design Team could learn a bit from you there - especially after their major design misstep in using those gaudy LED lamps in the headlight surrounds of some recent models.
Now, if you could just get some tiny LED's into the eyes of the Leaper...
Attached Thumbnails Oops, i did it again!! customize boot Plinth on a 2004 X-type-jaguar_small.jpg
Old Feb 27, 2013 | 11:09 AM
bracester's Avatar
Jaw drops...I have a 2.5...so want to look at trying this...
Old Feb 27, 2013 | 11:15 AM
jonesy1974xtype's Avatar
'Robert De Niro looking pleased and nodding in a Scorsese film.'
Old Feb 27, 2013 | 11:21 AM
retroreflective paint perhaps. To be fair boot/trunk plinths are not very pricey. could be worth the investment.
Old Feb 27, 2013 | 11:24 AM
bracester's Avatar
My other concern with it is water sealing...I suppose you could use some silicon before applying the leds to the back to make it water tight and use some waterproof sealed led's from the get go...
Old Feb 27, 2013 | 12:57 PM
joycesjag's Avatar
mad mike very well done. Thanks for the explanation.
I may be eye balling the wifes S Type this weekend as well!
Old Feb 27, 2013 | 12:59 PM
Aonsaithya's Avatar
The plinth style isn't dependent on engine size, the early models had the plinths with the green button in the middle while 2004> or so had the ones with less pointy ends and a hidden button. 2008> models have a wider plinth that spans the rear lights.
Old Feb 27, 2013 | 01:01 PM
Originally Posted by mad_mike
........... I cut out the "Jaguar" and added an LED light strip in the back..........
That IS dedication.
Old Feb 27, 2013 | 06:56 PM
mad_mike's Avatar
Well to answer the "?" About the water seal, the LED strip is for outdoor use and I just used the covers the came between the body and molding. I'm glad everyone liked it and I also posted a while back the side mirror LED mood. I put a strip of amber LED's behind the mirror so the turn signal glows behind the mirror.
Old Feb 27, 2013 | 07:16 PM
Mike......+1 on all the superlatives already used in the posts above.
I'm loving it, a really cool mod and one that looks a million dollars.
Thanks for sharing
Old Feb 28, 2013 | 12:39 AM
mad_mike's Avatar
Here is a pic of what i also did with my side mirrors. Only lights up when i signal.
Attached Thumbnails Oops, i did it again!! customize boot Plinth on a 2004 X-type-side-mirrors.jpg
Old Feb 28, 2013 | 06:44 AM
WhiteXKR's Avatar
Very impressive work Mike!!
Old Feb 28, 2013 | 06:47 AM
WhiteXKR's Avatar
Thanks, I have been looking for that information!
I have an emergency boot opener with a lithium backup battery soon to be released that uses a (owner settable) sequence of button presses to open the boot/trunk in the event of a dead battery or keys locked in the trunk.
(Not trying to hijack this thread....please contact me or open another thread to discuss.)
