P1646 DTC Code on 2003 Jaguar X-Type
Old Dec 11, 2019 | 07:04 PM
waverlycheatwood's Avatar
Default P1646 DTC Code on 2003 Jaguar X-Type
My Code Reader Say - "P1646 aux inputs, aux outputs". But when I look the Code up Online, it say's - "P1646 Jaguar - HO2 Sensor Control Malfunction Bank 1 Upstream". What Do I Do, What does this mean? Thanks
Old Dec 11, 2019 | 09:20 PM
avern1's Avatar
Hi Waverly, first off you are in the wrong section of the forum. The X-Type is the section is the X400. But we can still help. The code indicates a failure of the upstream HO2 sensor on the right bank of the engine. That sensor is just above the catalytic convertor on the exhaust manifold near the backside of the engine. It will need to be changed.
Old Dec 11, 2019 | 10:58 PM
Smile P1646 Problem
Thank You So Much Avern1...... Be Blessed!
Old Dec 12, 2019 | 02:36 AM
JagV8's Avatar
Just so you know, all P1 codes are make-specific but your tool apparently doesn't know (hard to believe!!) and so is misleading you.
Old Dec 12, 2019 | 10:22 AM
Thumbs up P1646 Problem
Thank You So Much JagV8! Be Blessed!
Old Dec 12, 2019 | 12:08 PM
I've moved your thread to the model appropriate X-Type forum.
Paul1313
Feb 20, 2025 05:49 PM
hm1
Aug 29, 2014 05:35 PM
nycxtype
Nov 20, 2011 02:58 PM
onlyshopping
Feb 6, 2010 05:50 PM
Tracy
Jul 13, 2009 11:47 PM
