Replaced air vacum hose.need to reset cruise not avail!
Old Sep 14, 2009 | 06:14 PM
xtype owner's Avatar
Cool Replaced air vacum hose.need to reset cruise not avail!
any one know if its a good idea for me to reset my message CRUISE NOT AVAILABLE message by unpluging my x type battery over night,i went to dealer and bought the ribbed hose(great deal 10 bucks)100 percent better than anyother hose i could use,anyway I was wondering if its a good idea to reset by unplugging battery,I did replace hose should be fine.
thanks
02 xtype 2.5
Old Sep 14, 2009 | 11:53 PM
mohrd's Avatar
The "cruise not available" should only show up if you are in limp mode. After you've changed the PCV hose you may have a lit CEL for a few more starts but if you've solved the vacuum leak, your dash reading should go back to normal. Do you perhaps have another leak? IMT valve o-rings, brake booster hose?
Old Sep 15, 2009 | 08:02 AM
Cool
Is there a way i can check if there is a leak in the imt valve o rings and brake booster hose mohrd?.
Old Sep 15, 2009 | 10:24 AM
Colt's Avatar
Banned
You might hear a sucking sound...but the dealer's usually change all the parts that Mohrd had mentioned to ensure they get all the possible leaks.
Old Sep 15, 2009 | 12:02 PM
does anyone have a pic im not sure were the two ten bolts are
thanks
Old Sep 15, 2009 | 12:03 PM
Originally Posted by jagtech514
What year is your POS x-type? The old seals are yellow and the new style are green. Unbolt the top imt with the 2 ten mm bolts. Slide the unit out from the plentum and insp the seals.
by pos do you mean to say year of vehicule?
Old Sep 15, 2009 | 12:13 PM
Colt's Avatar
Banned
P = Piece
O = Of
S = ****
Old Sep 15, 2009 | 12:53 PM
Originally Posted by Colt
P = Piece
O = Of
S = ****
colt you calling my car a pos?
Old Sep 15, 2009 | 12:55 PM
can i do this myself?if so easely my skill on cars are around 2 on 1-10
Old Sep 15, 2009 | 01:06 PM
Colt's Avatar
Banned
I ain't calling your Jag anything..
Did you not just ask what POS meant, written by jagtech?
Old Sep 15, 2009 | 01:30 PM
The Chris X's Avatar
POS is a generally accepted jargon abbreviation. Colt was just letting you know what the abbreviation stands for, he didn't call it that himself.
At this point you might want to cycle through some starts with the car and see if the CEL remains. Based on your self-rating on the automotive skill scale, perhaps it's time to call for some professional assistance if the light remains.
Old Sep 15, 2009 | 01:37 PM
Cool
I was joking colt...thanks anyway colt for the explanation never knew pos stood for that though,another thing If i had a pic it would help maybe someone wants to chime in with that,hmm cycle how may times 5-10 times,Ill try that i appreciate the advise
Old Sep 16, 2009 | 10:36 AM
Colt's Avatar
Banned
No sweat bro..I just didn't want you to think that yours or anybody's JAG is a POS..they are an ICON and have temperment issues..Love/hate kinda thing
Good luck with your issue...
Old Sep 16, 2009 | 10:06 PM
Colt's Avatar
Banned
Oh for pete sakes, give the guy a break...
Here is the (IMT valves) otherwise known as Throttle Control Valves..like Jagtech said, the old "O rings" are yellow and prone to leaking, the new ones are Green.
Old Sep 17, 2009 | 11:46 AM
Cool
thank you colt great pic!!
Old Sep 17, 2009 | 01:30 PM
If you do give it a go, good luck. You can't learn if you don't try. With the good folks on the board for help, I bet you can do the job. You might want to photo document your progress in case you get stuck in a spot, then post the pics and we'll try to steer you the right way.
Hope you get your Cat back up to top shape.
Old Sep 17, 2009 | 01:41 PM
Colt's Avatar
Banned
I will add..you will not be able to get the bottom IMT out all the way..but you will be able to slip the O rings over the front with a little stretching.
philwarner
Dec 6, 2021 07:13 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
big d
Sep 3, 2015 07:37 PM
XFR_Gold
UK & Eire
Sep 2, 2015 06:30 AM
dpappyp
Aug 27, 2015 06:31 AM
