so the engine light came back AGAIN! And a couple other questions
Old Oct 12, 2008 | 07:11 PM
rosemont83's Avatar
Default so the engine light came back AGAIN! And a couple other questions
Soo.. for about 3 weeks the check engine light has been gone but the other day it came back!
I got the p0171 and p0174. The codes mean: System Too Lean(Bank 1) and System Too Lean(Bank 2)
When the light was on, the car would sporadically enter safe mode and cut the fuel at 3000 rpms.. but then re-enter normal mode after a little time passes.
I reset the check engine light and its been alright again..
Would that be the air control valves, O-rings, and gaskets for the valves?
And what would be the formal name I would give the dealer or autozone to find the part? Autozone doesnt understand air control valves...
Today something weird happened also. I was driving, parked my car, turned it off, ran into a store, came back out started my car and started driving...
NONE OF MY GAUGES WERE WORKING!!!!!!
I went to go get some gas about a minute later, filled the tank, started the car, and everything was back to normal!
wtf mates.
Old Oct 12, 2008 | 07:46 PM
mohrd's Avatar
Default RE: so the engine light came back AGAIN! And a couple other questions
First problem is probably a vacuum leak. Best bet is to "smoke" test the intake. I thought mine was just the PCV hose but ended up with three leaks, the IMT o-rings, brake boost hose and the PCV hose all had leaks of some sort. If all are the original, probably should look at replacing all three. The PCV hose tends to split along the bottom, brake boost has a check valve that breaks down and the o-rings are quite common.
I don't have a guess about the gauges except an intermittent electrical problem.
Old Oct 12, 2008 | 09:40 PM
rosemont83's Avatar
well I found out what the light should be from...
I heard a hissing noise coming from one of those valves and I was suspect.
So I grabbed some throttle body cleaner and sprayed it...
the car went "guurgle guurgle" so there is definitely a leak there..
probably the o ring in that valve thing
Old Oct 12, 2008 | 09:49 PM
racerx82's Avatar
Give me a holler if you need the O-ring
Old Oct 12, 2008 | 10:28 PM
rosemont83's Avatar
I do need the O ring!
Unless my uncle can pick one up tomorrow..
You have the part with you?
Old Oct 12, 2008 | 11:31 PM
scubayachts's Avatar
I need the oring tooo! Do you have extras. I can hear that fint hissing leak from the control valves or thats atleast that what I think they are. Let me know!
Old Oct 13, 2008 | 08:04 AM
racerx82's Avatar
I only have one, sorry. I'll have to look in my many boxes of jag parts. geesh, i really need to put all this stuff on ebay.
Old Oct 13, 2008 | 12:38 PM
JagXV6's Avatar
What does IMT stand for and where are these air valves?
Old Oct 13, 2008 | 08:36 PM
BuckMR2's Avatar
Might be worth checking this out too:-
Had this on mine the other week (limp home mode lean banks 1 and 2 sometimes OK mostly not) turned out to be a 3" split under one of the hoses.Dealer reclons common fault and cost £5 for new pipe (much sturdier than old one)
Old Oct 13, 2008 | 09:00 PM
mohrd's Avatar
IMT = Intake Manifold Tuning, I believe. Both are located on the left side of the intake as you are looking at it from the front of the car (passenger side in North America). There are o-rings in each of the upper and lower.
Old Oct 13, 2008 | 09:03 PM
Dennis's Avatar
ud
Yup..it's these guys here..
Old Oct 13, 2008 | 09:41 PM
Brutal's Avatar
if you have yellow orings theyre original andtoo small and leak easily, the upgraded new ones are green. anytime you have a lean codes on an Xtype youre better off replacing IMT orings, brake booster vacuum line and PCV hose.. all 3 are problem ares
Old Oct 13, 2008 | 11:13 PM
rosemont83's Avatar
those are exactly the culprits..
and yes... they are both yellow!!!
Thats called the IMTs?
I tried calling the dealer but they wanted to give me a breather something..
and a crankcase hose..
lol..
the pcv hose on mine seems to be fine..
but where is the brake booster vacuum line at?
Old Oct 14, 2008 | 06:09 PM
mohrd's Avatar
Breather hose/crankcase hoseis the PCV hose. If it isn't "ribbed" it's probably the original. If it's original, it's probablycracked or split on the UNDERSIDE. Pull it andhave a look.
Brake boost hose runs from the back of the intake over to thebrakebooster. Has a buldge in the middle where the check valve is. If the check valve is white it is probably original and is decayed. If you (or anyone else I guess)needa brake boost hose, I have one. Brand new. Still in package.
Old Oct 14, 2008 | 08:53 PM
Dennis's Avatar
ud
My dealer called thoseIntake Aircontrol Valves (upper/Lower)..at least that's what they wrote on my service invoice.
Part Numbers:
Seals C2S40669 (2 each)
Gaskets C2S14519 (6 each)
Gasket XR819852 (1 each)
Maybe Someone can explain why all the gaskets....But whatever they did, it fixed mine for the same reasons above.
Old Oct 14, 2008 | 09:56 PM
racerx82's Avatar
Sounds like they replaced the 2 control valve gaskets, 6 intake gaskets and 1 throttle valve gasket.....(they wanted to be sure they got them all) lol
Old Oct 14, 2008 | 09:57 PM
Dennis's Avatar
ud
ORIGINAL: rosemont83
Right here...
Old Oct 14, 2008 | 09:59 PM
racerx82's Avatar
Damn Dennis, you're on the ball! I always knew that though.....
Old Oct 14, 2008 | 10:13 PM
Dennis's Avatar
ud
Thanks for the P/N break down..I knew you'd know..
Old Oct 14, 2008 | 11:24 PM
rosemont83's Avatar
lol..
thanks guys.
got all the parts and put them in.
no more hissing noises..
except now there seems to be a hissing from under the car.. like an air leak..
i was like wtf??
lol.. should be fine..
but thanks guys!
everything I replaced was still the originals so its a good thing I got the other stuff anyways.
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
Spikepaga
Aug 30, 2015 12:59 PM
Jandreu
Aug 29, 2015 07:31 PM
dpappyp
Aug 27, 2015 06:31 AM
