Strange rear suspension problem.
Old Nov 7, 2010 | 11:48 AM
imgouki's Avatar
Unhappy Strange rear suspension problem.
Has anyone had this problem with the rear of their x-type? Mine is a 2001 3.0 sport with low mileage. Had a rumbling at the rear , following a
previous treads , changed the rear anti-roll bar bushes and drop links. Problem seem to go , now when with either a load or rear passengers , the rear wheel will hit the wheel arch near the bottom by the rear door on the passenger door. Is it an obvious fix or does it sound the rear sub frame bushes are gone ? Help !
Dampers and springs were checked o.k. , have never seen this on any cars i have owned before , very strange !
Old Nov 7, 2010 | 12:25 PM
LEB's Avatar
LEB
Check to see if the lower control arm is bent. I accidently lift the rear of my car on it and twisted it so that the wheel is closer to the wheel arch. I used a sledgehammer to bend it back mostly... but I think it's best to replace for $100 and a little time. Should go for an alignment afterwards. Gotta put this on my to-do-list.
Old Nov 7, 2010 | 01:36 PM
TheSeeker's Avatar
I agree with LEB.
I once had a tire shop that was changing my tires for the winter lift the car by putting their lift blocks on the lower rear control arm and bent one of them. They are quite flimsy and only designed to handle a load in one direction....easily bent/twisted.
Old Nov 7, 2010 | 03:51 PM
imgouki's Avatar
Thanks guys , will get checked as soon as i can. But a hammer ? Think if that's the case will get a new one , are they easy to fit ?
Old Nov 7, 2010 | 04:04 PM
TheSeeker's Avatar
Believe it or not, you can bend those things quite easily with a hammer, channel locks, or as I used....a hydraulic jack to get them back to shape.
If you soak down the bolts and stuff overnight with liquid wrench before you go about the replacement, then you shouldn't have a hard time. However, yes, 4 wheel alignment would be in order after you're done.
Old Nov 8, 2010 | 06:12 PM
imgouki's Avatar
Have not had a chance to check it yet , busy at work. But one thing concerns me , having a look at the part mentioned , cannot see how a vertically hinged arm can cause the wheel to move laterally, especially under load? If it was bent would it not be obvious from the get go. Thought i would see it straight away?
Old Nov 8, 2010 | 06:22 PM
TheSeeker's Avatar
They can twist so to speak.
I can't answer the "how" part, but I can attest from experience that when it was bent, I got a fairly loud knock sound and a rumble that seemed like it was coming from the rear wheel arch area.
Old Nov 9, 2010 | 12:28 AM
imgouki's Avatar
Yep, they are the symptoms i am having. Wonder if it's a problem that has been addressed from jag?
Old Nov 9, 2010 | 06:49 PM
TheSeeker's Avatar
They need to put a large orange sticker on them that says "NOT A JACKING POINT!".
Old Apr 1, 2012 | 04:02 PM
jagtime's Avatar
Default jagtime
Hi sorry cant help with rumbling as i have the same under my x-type 2.5 SE when driving on uneven road the rumble comes from rear on smooth road no rumble at all ,can anyone help please
GordoCatCar
Jan 2, 2017 01:10 PM
carelm
Sep 5, 2015 01:13 AM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
