Tranny fluid leak?
Old Dec 24, 2011 | 08:29 PM
04X-Type's Avatar
Default Tranny fluid leak?
So I was doing an oil change and I noticed tranny fluid on the drain plug. I wiped it off and went for a drive, put the car back on the lift and noticed fluid leaking from the seal in-between the trans and transfer case.
Anyone dealt with this? If yeah, what is the gasket called? A local mechanic said I might have to rebuild the trans if I remove that seal. I think hes trying to get more money out of me. So the question is, what route do I take? Take-in to consideration I want to keep the car.
It's a 3.0 automatic
Old Dec 28, 2011 | 05:28 PM
brucelee's Avatar
I think it is called the rear main seal.
Old Dec 28, 2011 | 08:59 PM
motorcarman's Avatar
The seal is a thin 'O'ring (C2S5132). It is on a flange that is part of the transfer case so the CV axle shafts need to be removed and the splined shaft displaced to move the transfer case from the gearbox. The 'O'ring seal will leak red ATF when it fails.
You might get away with pulling the transfer case and shaft just far enough to change the 'O'ring.
bob gauff
Old Dec 29, 2011 | 08:11 AM
04X-Type's Avatar
Bob, thanks a lot. I'll get on that right away. Dealer was trying to charge 200$ just check the fluid level.
aholbro1
Dec 29, 2024 06:46 PM
picard
Oct 12, 2015 11:56 AM
JeffinSwitz
Sep 16, 2015 01:44 PM
sogood
Sep 15, 2015 07:35 AM
Richard_gib
Sep 12, 2015 07:08 PM
