Where are downstream 02 Sensors of 2.5 Xtype?
Sorry dont want to sound special ed but when im under the car lifted from the front i see a long pipe that goes to the back and splits up into the two seperate exhaust ports. The pipe connects to manifold also. In short im kinda lost on what the cats look like and where after them are they. Any pics would help. Thanks
Yep :-)
What makes you think the O2 sensor is bad?...did you read a code or something?..I've not heard in all the problems that the X-type has, that the O2 sensors are ever a common problem or they are rarely a problem...Not saying you do not have a bad sensor(s)...but look into other things that give you bad O2 readings first.
I am getting codes P0420 AND P0430. I will change cats when I can afford to do so but I need to renew licences plates now. So just trying defouler trick and need to know how to get to o2 sensor 2.
FS[SouthEast]: X300 XJR engine & misc parts
knightofgold
Feb 11, 2016 06:03 PM
Poet
Oct 6, 2015 09:40 PM
Roger Mabry
Sep 15, 2015 09:22 AM
