2012 XFR Fusebox Diagram
Old Dec 22, 2016 | 10:13 AM
Joba's Avatar
Default 2012 XFR Fusebox Diagram
Hi ,
Im new to here and I desperate need help since my left side headlight stop working .
Since the manual I have at hands wont mention where the fuse responsible for this is located then Im totally lost. Can somebody please help me with a fusebox diagram or location for this fuse or even maybe a possible cause for this instead of lamp itself which was tested and its ok ?
thx in advance
Old Dec 22, 2016 | 10:37 AM
Welcome to the forum,
Try here XF Fuses
Don't forget to post an intro in the new members section.
Old Dec 22, 2016 | 04:39 PM
OzXFR's Avatar
The XF lighting system doesn't use fuses, it uses FETs (Field Effect Transistors), so mucking about with fuses or the fuse box won't fix your problem.
Old Dec 23, 2016 | 09:25 PM
Joba's Avatar
Thx a lot both Norri and OzXFR ... After checking other possibilities was finally discovered that a cable simply disconnected who knows why ...Vibrations or whatever... Problem solved...
Old Dec 23, 2016 | 09:36 PM
Good news Joba, time for that intro now?
Old Mar 12, 2021 | 02:04 PM
David Wood's Avatar
Hi Norri
I hope you can help me to find the fuse that powers the 12v sockets in the console, i would like to piggyback the apropriate fuse to power two dashcams.
please dont refer me to this xf fuse link as the fuses in my cjb do not match the fuses in that or my manual .
regards
Dave Wood
Old Mar 13, 2021 | 01:41 AM
u102768's Avatar
This is for a 2011 UK car so hopefully matches yours.
File Type: pdf
Old Mar 13, 2021 | 01:53 AM
John Williams's Avatar
The socket under the lid in the consul is fused as "Auxilary power" Where the socket in the front of the consul is fused as "Cigar lighter".
Old Mar 13, 2021 | 07:06 AM
David Wood's Avatar
Default My CJB
Hi Norri
Thanks for the info but I still have anomilies with the fuses I have in my fusebox.
This is what I have, another question is which fuses stay live when the stop/start system kicks in, Sorry for all the questions but its hard to check that when it happens.
Regards
Dave
Jaaaggg
Jul 20, 2024 10:08 PM
Jacko5711
Dec 22, 2019 07:51 PM
baloozman
Jun 12, 2019 07:21 AM
3kgtjunkie
Jun 7, 2019 09:19 AM
BobbyDing
Jan 29, 2019 08:25 AM
