2013 tail lights on 2010 XF
Old Dec 16, 2014 | 07:13 PM
philhef's Avatar
Default 2013 tail lights on 2010 XF
Ok. So I know this has been discussed but not finding.
I have a set of 2013 XF tail lights and plan to swap on my 2010 XF.
Not being a complete idiot, I realize the harness plug is the same but the pins are in different locations. The wires are all the same colors so I'm hoping someone here can tell me if simply relocating the pins to the correct location will work. Or am I going to have to have resistors due to the new led capacity loads??
Old Dec 16, 2014 | 07:22 PM
Ajay Mann's Avatar
you would probably need to replace the hood as well
Old Dec 16, 2014 | 07:26 PM
chXFS's Avatar
Originally Posted by philhef
Ok. So I know this has been discussed but not finding. I have a set of 2013 XF tail lights and plan to swap on my 2010 XF. Not being a complete idiot, I realize the harness plug is the same but the pins are in different locations. The wires are all the same colors so I'm hoping someone here can tell me if simply relocating the pins to the correct location will work. Or am I going to have to have resistors due to the new led capacity loads??
You have to repin and use resisters. I have face lift lights as well. But have been lazy to do it. I will try and dig up the how to thread from the UK forum.
Old Dec 16, 2014 | 07:39 PM
chXFS's Avatar
Here is a pic with mine in, they plug right in. Same as pre facelift. But have to be re pinned. The resisters are only for your dash indicators.
Stock is on the left, face lift on the right.
Attached Thumbnails 2013 tail lights on 2010 XF-image-3670715887.jpg   2013 tail lights on 2010 XF-image-2880078174.jpg
Old Dec 16, 2014 | 08:37 PM
philhef's Avatar
Already added the center boot lights. I wired them to the license plate wiring. Works perfectly but I unwired until I have entire assembly in.
Old Dec 16, 2014 | 08:39 PM
philhef's Avatar
Other thing, the lights in the older assemblies are led as well so shouldn't they have correct resistors? I noticed the same replacement bulbs and such in the new as in the old so........
Old Dec 16, 2014 | 09:40 PM
chXFS's Avatar
They have to be re pinned. You just get a small set of needle nose and rearrange the pins in the socket. If you don't mind the blinker indicators flashing on the dash fast, then you don't have to use the resistors. The blinkers on the outside of the car will blink like normal, it's just the ones in the car that will blink super fast.
Old Jul 7, 2015 | 12:42 AM
Shane7's Avatar
So do you guys know where I can order face lifted boot lights and also the main lights for reasonable price or something.. Could u walk me through it
I live in Toronto are there any good local places could sell from where should is start
thanks
kj07xk
Dec 18, 2025 10:56 AM
Dagny
Jun 11, 2024 01:06 PM
D.K
Dec 10, 2023 02:05 AM
Armor6
Sep 14, 2015 07:56 PM
motorhead69
Sep 9, 2015 10:04 AM
