Black smoke after driving for 2 miles - RESOLVED
Old Jan 15, 2021 | 02:47 PM
KayC's Avatar
Default Black smoke after driving for 2 miles - RESOLVED
Any idea why an XF would smoke (black) after being driven for 2 miles but never smoke on idle? Like new engine replacement, no CEL, engine torque or sound not affected, oil level ok
Last edited by GGG; Jan 21, 2021 at 04:32 AM. Reason: Add "RESOLVED" to thread title
Old Jan 15, 2021 | 04:33 PM
kansanbrit's Avatar
Oil overfilled ?
The problem with no dipstick is that you can't see if it is overfilled.
Old Jan 15, 2021 | 05:32 PM
Six Rotors's Avatar
Usually black is over fuelling if it is a gasoline engine. What engine is in your car?
Old Jan 16, 2021 | 12:36 AM
KayC's Avatar
Originally Posted by kansanbrit
Oil overfilled ?
Oil level is okay according to the display panel, and it only smokes after it has been driven for 2 miles.
Old Jan 16, 2021 | 12:38 AM
KayC's Avatar
It's a petrol engine, what could be the cause of the overfuelling when driven?
Old Jan 16, 2021 | 04:09 PM
Six Rotors's Avatar
So is this a 3.0L Supercharged engine? Have you just had a new engine installed? Are you saying that you have no warning lights on the dash? Are you saying that the engine otherwise runs normally with respect to power, smoothness and no strange noises? How long do you see black smoke for? Is the black smoke coming out of the exhaust tail pipes? How much black smoke is there? Does it go away if you run the car for 5miles,20 miles,3 hours?
Does it smoke regardless of throttle position? Or just when you give it full throttle? What is instantaneous fuel consumption reading compared to what was normal before the black smoke started?
Old Jan 16, 2021 | 11:04 PM
KayC's Avatar
So is this a 3.0L Supercharged engine? Yes
Have you just had a new engine installed? Yes
Are you saying that you have no warning lights on the dash? No warning light
Are you saying that the engine otherwise runs normally with respect to power, smoothness and no strange noises? Correct, runs smoothly
How long do you see black smoke for? Once it starts, it doesn't stop till the engine cools
Is the black smoke coming out of the exhaust tail pipes? Yes
How much black smoke is there? A lot, quite embarrassing
Does it go away if you run the car for 5miles,20 miles,3 hours? It doesn't
Does it smoke regardless of throttle position? Yes
Or just when you give it full throttle? Smokes more when throttle is pressed
What is instantaneous fuel consumption reading compared to what was normal before the black smoke started? Around city 16mpg...ltft on both banks are negative.
Old Jan 21, 2021 | 01:32 AM
KayC's Avatar
Just figured it out, smoking was due from the oil and coolant residue left in the exhaust by the blown engine.
Old Jan 24, 2021 | 09:45 PM
Aarcuda's Avatar
Lol. I was gonna say oil on the exhaust pipe. Btdt
Ajohnsonnefn
Jun 18, 2023 02:45 AM
SteveP15ftypeR
Dec 5, 2016 10:01 AM
Paul Stead
Aug 2, 2014 12:23 PM
alex-john76
Jul 8, 2011 05:41 AM
monz87
Dec 14, 2009 12:08 PM
