Dented decal on airbag - XF
Old Feb 20, 2014 | 06:00 AM
After a number of reports of this issue, I've contacted Jaguar CRC in the UK (see original message and reply below).
Any individual with a dented decal should send a PM to Mike@Jaguar giving:
1. VIN
2. Name
3. Contact details
Mike will look into this issue.
Originally Posted by Mike@Jaguar
Hi Graham,
To be honest this isn't something I have heard of before so do not know the answer.
If individual customers are having this issue then they can PM me their details (VIN, Name, Contact details etc) and I will get this looked into.
Many Thanks
Mike
Originally Posted by GGG
Good Morning Mike,
We have had a number of posts from XF and XK owners about denting the badge in the centre of the driver's airbag when using the horn.
Is there a repair/replacement procedure for this badge? US dealers are suggesting the only option is to replace the airbag.
Regards,
Old Feb 20, 2014 | 11:51 PM
wannajag's Avatar
I asked this question a while back and was left wondering if the crest on the airbag cover was built with an indent from the factory. Seemed nobody knew otherwise, mine is perfectly and symmetrically indented right on top of that cats nose.
Anybody?
Old Feb 21, 2014 | 04:03 AM
OzXFR's Avatar
Anybody?
Same here, mine is perfectly and evenly indented, so I assumed that's how it came from the factory!
Old Feb 21, 2014 | 05:23 AM
Mine is unmarked with no indentation.
This is how I would expect it to be from the factory.
Old Feb 21, 2014 | 06:03 AM
cwood's Avatar
Guys its a common problem and it is caused by an aggressive push on the horn....its too thin. I started this post last week.
https://www.jaguarforums.com/forum/x...rowler-111456/
I can't find anyone on the forum with a handle of Mike@jaguar.
Old Feb 21, 2014 | 06:50 AM
Schwabe's Avatar
Jaguar Forums - Jaguar Enthusiasts Forum - View Profile: Mike@Jaguar
here is his homepage. I sent him a PM already. The more the merrier....
Attached Thumbnails Dented decal on airbag - XF-%24-kgrhqr-lqfh327fv1qbr-k6kmtbq%7E%7E_4.jpg   Dented decal on airbag - XF-%24t2ec16jhjgeffm088j-vbr-k6ndflw%7E%7E_4.jpg
Old Feb 21, 2014 | 07:32 AM
Originally Posted by cwood
.......... I can't find anyone on the forum with a handle of Mike@jaguar.
Check my post #1
It's Mike@Jaguar with leading capitals.
Old Feb 21, 2014 | 08:19 AM
Brutal's Avatar
exactly, and since it didnt come that way from the factory, its not a warranty issue. But I do agree, someone should have thought that one out alittle bit when getting that designed and made for Jag.. Maybe someone could get new ones made to replace the growler with something like "ROCKET LAUNCH"
Old Feb 21, 2014 | 08:39 AM
Originally Posted by Brutal
........ But I do agree, someone should have thought that one out alittle bit when getting that designed and made for Jag..
The decal has to be lightweight to prevent any risk of injury in the event of airbag deployment. Previous models had an embossed Jaguar logo or script and it could have been better to stick with this design.
Probably Jaguar never expected anyone would take their hand off the steering wheel to hit the centre decal. The horn is designed to operate by pressing anywhere on the pad.
Old Feb 21, 2014 | 06:02 PM
Schwabe's Avatar
Wow, already had a call back from Jaguar this afternoon. Explained that it had go be light for safety reasons when airbag deploys. And that there is really nothing they can do if it wasn't delivered with the defect or at the very least within the first year of ownership. Still believe everyone should contact them to show that it is an issue that needs to be addressed. A $1,000 repair for such a simple mishap is not fun to deal with.
Old Mar 4, 2014 | 06:42 AM
robertccc's Avatar
It is normal that the airbag cover can be removed from the airbag module once removed from the steering wheel. Reminder to disconnect battery before as an unwanted voltage could deploy airbag. With the cover off you can likely push from the rear of the cover to push out dent. Not sure I would recommend pulling off the emblem to do this. Need to make sure the attachment is as sound as original. The cover is designed to tear apart during deployment with the emblem staying intact on one half. It's not a desirable condition to have the emblem separate from the cover during an airbag deployment (projectile)
I have not done this on jag but seen many other driver airbags with similar covers and emblems
wichita
E type ( XK-E )
Apr 16, 2016 04:00 AM
bdboyle
Nov 6, 2015 02:07 PM
Jaguar Forums Editor
Jaguar Press release
Sep 28, 2015 05:18 PM
Tahoe Dave
Sep 28, 2015 07:42 AM
