Leak in footwell
Old May 25, 2022 | 09:03 AM
Kirk Holmes's Avatar
Default Leak in footwell
Hello everyone,
we had a storm last night and i have a pool of water in the passenger footwell. The carpet under the dash behind the glove box is dp around half way across so water most likely comming from above.
Does anyone have any knowledge of this as a common fault or have experience of most likely cause?
Thanls in advance
Old May 25, 2022 | 09:16 AM
pab's Avatar
pab
First thing I would do is to check that the Sunroof drains are clear.
Current Hers: '13 Lexus ES350
Current Mine: '15 Jaguar XF (X250) Portfolio AWD
Jaguar - making mechanics out of customers since 1935
Old May 25, 2022 | 09:28 AM
Hi thanks for the response. No sunroof in my xfr.
Old May 25, 2022 | 09:13 PM
POD XF's Avatar
This may or may not be relevant to your situation but I recently discovered I had a serious leak from the airconditioner condensate drain, there was water under the carpet the whole way through the floor. If it's soaked from below, the carpet will probably wick the water above the source. If you're certain it was dry before being in the rain and then wet after, the a/c is probably not your source but worth considering. The thing that tipped me off that the water I had was condensate rather than storm water was the fact that the water in the floorpans was crystal clear, whereas rain water will likely carry grime with it as it gets in.
Old May 26, 2022 | 01:22 AM
Bigv's Avatar
Blocked scuttle drains?
Old May 26, 2022 | 06:35 AM
Thanks, the carpet under the glove box was damp so i think the water is from above. Going to check scuttle drains today but think they are clear.
Old May 26, 2022 | 10:36 AM
Is this whay is meant by the scuttle drain? I pulled loads of crud out with some long nose pliers.
Old May 26, 2022 | 11:15 AM
Bigv's Avatar
Think so!
kinda hard to tell
pour some water in and see where it goes
Flying Finn
30
Oct 22, 2023 05:22 PM
No Quarter
Jul 14, 2021 05:30 PM
Sportjag
Jul 8, 2021 11:14 AM
Trevor Martin
Jun 26, 2020 05:48 PM
EcbJag
Apr 18, 2012 09:30 AM
