Mahle/OEM Expansion Tank Defects + Check your radiator.
Old Oct 30, 2021 | 03:49 PM
index1489's Avatar
Default Mahle/OEM Expansion Tank Defects + Check your radiator.
I’m on my 4th expansion tank ordered.
The first 3 from Mahle ended up having casting flaws, leaking or had a sensor with ears not to specification so that the metal clip on the connector wouldn’t clip in properly.
I finally ordered a Genuine Jaguar one and after installing it I went to fill up the coolant and I noticed the top black cap that holds the float seems to have excessive plastic from casting. 12/2018 build date.
Not concerned on looks only if those pieces can break off and clog the system.
I also found the main system radiator extremely clogged up with leafs and other debris. There is a aero piece under the car that directs flow to the 3 radiators in front.
The first two weren’t too bad. I think this might be the cause of the fan running at low speeds for 30 seconds after engine shutdown.
Old Nov 1, 2021 | 04:59 PM
index1489's Avatar
This is what the parts place told me,
Old May 9, 2022 | 02:19 AM
index1489's Avatar
Bumping this to see if anyone has noticed this with a genuine expansion tank replacement.
Old May 9, 2022 | 12:05 PM
Paul Fisher's Avatar
I am about to buy one to keep in my stash of "consumables" and I will have alook and report once it arrives.
Old May 19, 2022 | 09:20 AM
Reaxions's Avatar
I need a new one, so I'm also curious.
Old May 23, 2022 | 09:29 PM
index1489's Avatar
Thanks, awaiting updates.
Old May 28, 2022 | 09:42 AM
Got my expansion tank yesterday, I bought it frm Jaguar of Palm Beach, FL as I wanted to be sure it was OEM stock and it is fine, no residue from molding in the pipe and the join line is solid all the way around.I paid more than I would have for an ebay part but as I had hoped it is genuine and looks to be a good part.I have not fitted it as my original is still doing fine but at 48K miles I'm keeping a close eye on things under the hood.
Old May 29, 2022 | 03:03 PM
index1489's Avatar
Thanks for the updates, waiting for anyone else to post a photo of their OEM tank!
Thorsen
Jun 16, 2021 01:08 AM
BlackKat
33
Jun 21, 2019 05:06 PM
RA110623
May 4, 2019 05:53 PM
Crackerbuzz
Nov 14, 2018 05:58 AM
ulshaferkl
Jan 15, 2015 10:42 AM
