New KVM Issue
Old Apr 21, 2024 | 07:34 AM
evanscornelius's Avatar
Default New KVM Issue
Hello all, i'm wondering if someone could help me or point me in the right direction or even let me know what i'm doing wrong. So i received my brand new kvm today and i hooked it up and ran the usual scans. So i erased all keys because they were only programmed to the cluster and that was the only way to start the car. They did not control anything else like locks, alarms or regular start. I configured the module as new and tried to program the keys as passive keys. I tried programming them as existing and as new keys and when it came time to press the unlock button on the fobs nothing happen and so i get key learn failed every time. 1 key i have is the original with a good battery and the other key is brand new. I've tried immobilize, configure bcm as existing and new, configure bcmb as existing and new, configured kvm as existing and new, key programming, verifying keys. It shows as 2 keys programmed and 0 keys passive. If anyone knows the issue i would be most grateful.
Old Apr 21, 2024 | 09:03 AM
John Williams's Avatar
Copied from a guy on facebook......
Car won't lock after battery disconnect. This is solved via immobilisation in SDD.
Issue two less common:
Key not recognised at all hence no ignition, immobilisation not possible.
This is done via cluster reprogram as it will bypass the key sequence, turns ignition itself and do the immobilisation at the end.
This will also update cluster to latest software, bonus.
Please don't throw suitcases of money on KVM module/keys and what not, I've never seen a faulty KVM module.
Old Apr 21, 2024 | 10:05 AM
So i've gotten the vehicle started via the cluster but i have to put the fobs in the starter unit to start the vehicle and fobs still don't control locks, alarms etc. The original kvm that was in the vehicle kept getting communication lost. Tried modifying it as existing and as new module but the same lost communication error every time. After the new one was installed every thing went fine until it came time to program the keys. Learn failed every time and even though the new kvm updated, under the kvm section i'm getting 2 unknown parts. I also saw something that said kvm compatibility issue which is weird since the module is straight from the jaguar manufacturers and part number is exact. I'm assuming it may be the keyless entry antenna that's not picking up any fob that's in or around the vehicle. F.Y.I. i bought this vehicle from someone who was having issues with key not recognized so they just decided to sell it. Seemed like a easy fix...lol
Old Apr 21, 2024 | 06:42 PM
dennis black's Avatar
On your SDD go down to the option reset to factory ,try that first
Old Apr 21, 2024 | 07:06 PM
I don't have that option in my sdd version. I have version 164
Old Apr 21, 2024 | 07:47 PM
Default KVM Question
Hello everyone.
I bought a brand new KVM from Jaguar and while programming it as new module i got this message. Does anyone know how to rectify it. I think it is my issue for why i can't program any keys.
Old Apr 22, 2024 | 03:57 AM
Originally Posted by evanscornelius
Hello all, i'm wondering if someone could help me or point me in the right direction or even let me know what i'm doing wrong......
Welcome to the forums evanscornelius,
I've merged your latest thread on this same topic with your original thread. Please keep the discussion in the one thread.
Old Apr 22, 2024 | 10:36 AM
clubairth1's Avatar
Community Influencer
Looks like your missing the update files?
Have you tried downloading additional files?
It's under settings and says download calibration files. I have let the system keep doing this until it says there are no more?
I have never had a situation where I did NOT have the needed files because of this (I think?).
Old Apr 22, 2024 | 12:00 PM
Did you at any point disconnect the battery
Old Apr 23, 2024 | 04:18 AM
Yes
Old Apr 23, 2024 | 07:39 PM
Are there any used modules that we can install and program to our vehicles without needing to virginize them first?
Old Apr 27, 2024 | 03:12 PM
Does anyone know the location of the keyless entry receiver module in a 12 jaguar xf
Old Apr 27, 2024 | 05:40 PM
Six Rotors's Avatar
There is a Keyless Vehicle Module in the trunk of 2010 and 2011 cars. I do not know about the 2012.
Old Apr 27, 2024 | 06:00 PM
The 2012 kvm module is also in the trunk but im looking for the receiver, not the antennas
Old Apr 28, 2024 | 03:43 PM
Six Rotors's Avatar
Well there is a central locking RF receiver under the rear of the headliner(again for 2010/2011 models.
Old Apr 28, 2024 | 04:46 PM
Yes, that's the one I was looking for. Thank you so much
Old Apr 30, 2024 | 05:20 PM
Update: Once i replaced the rf receiver i was able to program my passive keys to the car. Thanks guys
Old May 17, 2024 | 07:10 PM
xalty's Avatar
you will always get that. softwaremanager will pop up and download the calibration
Old Oct 7, 2024 | 04:23 PM
Downloader's Avatar
Hey man, I'm facing the same issue with a 2007 X150, quick question...when you mentioned you were getting communication problems that lead to replacing the KVM do you remember what those were or the codes?
I'm having communication issues but they codes about different modules like :
ABS lost communication with speed control module
CCM invalid data received from ABS control module
FLR invalid data received from ECM
BCM Passive key
Found these while chasing the issue with the keyless entry and Smart Key not found problem after the battery died, also just discovered that my KVM reports 0 keys programmed but the car still works with the key on the slot since the Instrument Cluster has both transponders in its memory.
Read on another forum about a guy experiencing issues with CAN communications and had to disconnect the ABS sensor before programming and then everything went well.
Just want to see if someone had a similar experience before experimenting....don't wan to make things worst.
Thank you,
Old May 17, 2025 | 09:55 PM
Bleenkbak's Avatar
Not even if a locksmith erased original code data from it? Can original kvm still be used? If not, what are other options?
Kjamo
May 18, 2022 10:56 AM
Pirate
Apr 16, 2022 02:50 PM
mrNewt
Aug 28, 2021 06:32 PM
pragmatic
May 25, 2017 08:40 PM
JagCoast
May 11, 2015 07:43 PM
