rotton egg smell
Old Dec 5, 2015 | 06:19 AM
cliff ball's Avatar
Default rotton egg smell
hiya all has anyone got an idea why my car smells off rotten eggs when running its a 2.7 diesel 2009 modal have cleaned and replaced washer fluid as thougt that could have caused it but not IDEAS PLEASE .THANKS Cliff
Old Dec 5, 2015 | 09:19 AM
n8ertot's Avatar
Where are you smelling it? Can you find any place where it's stronger?
Old Dec 5, 2015 | 09:55 AM
Could be a bad cell in the battery.
Old Dec 5, 2015 | 03:06 PM
OzXFR's Avatar
Rotten egg smell = sulphur dioxide.
Commonly happens when a catalytic converter stops working properly.
Old Dec 5, 2015 | 10:03 PM
BritCars's Avatar
Apparently you can get a smell like that when the AC drain tubes get blocked and water backs up. Think you can clean them yourself although I don't know details of how best to access it
Old Dec 6, 2015 | 03:57 AM
cliff ball's Avatar
cheers that make sense. as checked all the other faults .thanks again cliff
Old Dec 6, 2015 | 04:00 AM
cliff ball's Avatar
thanks for getting back i have been told possible ac drain blocked which sounds a good call as have checked most other things ..cheers cliff
Old Dec 6, 2015 | 11:04 AM
n8ertot's Avatar
In the spirit of starting where it's easiest, have you replaced your cabin air filter? They sometimes will get wet and moldy and can make that smell. Honestly, I haven't replaced mine since owning this car, so I'm not sure where it is, but I know this is a common issue to all cars.
Old Dec 6, 2015 | 07:12 PM
DPK's Avatar
DPK
To be clear before you start changing batteries or cabin filters,..Where do you smell this odor?..Inside the car or outside by the exhaust? and when an how do you smell it?..i.e., environmental control settings, car running, at start up, or after a run to the local *** shop and back, etc.
Old Dec 7, 2015 | 04:05 AM
cliff ball's Avatar
thanks for getting back ill check see if they have been done cheers cliff
Old Dec 7, 2015 | 04:12 AM
cliff ball's Avatar
thanks for getting back. To be honest with you i still think it could be stagnent water as it seems to happen after using screen washers when i get a chance ill clean out the screen washer bottle again .cheers cliff
Old Dec 8, 2015 | 12:40 PM
cliff ball's Avatar
hiya again i have cleaned washer bottle again but smell starts to come in car as soon as i start engine and auto vents open could it be filters and if so do you know the location of them ..cheers Cliff
Old Dec 8, 2015 | 12:49 PM
n8ertot's Avatar
https://www.jaguarforums.com/forum/x...2009-xf-73099/
Old Jan 10, 2016 | 08:21 PM
Cherry_560sel's Avatar
Oz answered your question. Sometimes we dont want to hear the truth. Your cats are on their way out.
Old Jan 11, 2016 | 08:05 AM
cliff ball's Avatar
checked all cats in the area still all there.but about the smell turned out to contaminated washer bottle and jets cleaned out system and also renewed cabin filter all good now.
jackbrown_890
May 17, 2016 07:56 AM
JBReading
Dec 3, 2015 04:27 AM
TweeTwee
Nov 30, 2015 09:56 PM
andyXJR
Nov 30, 2015 11:56 AM
OzXFR
Nov 29, 2015 10:57 PM
