SDD Transmission Adaptation Crashes
Old Dec 17, 2020 | 02:25 PM
Jaizero's Avatar
Default SDD Transmission Adaptation Crashes
Looking for someone with experience with SDD V160.
After having the fluid, pan, and filter replaced on my 2015 3.0L SC, I performed the transmission adaptation reset which was successful. When trying to run the relearn process, SDD crashes and forces me to start another session. I have SDD running on a modern Windows 10 64bit laptop, but have tested this same procedure with an older Windows 7 32bit machine with the same result. My copy of SDD is directly from the IDS download page, but I am not logged in with a legit Topix login.
The error log shows a lot of java calls, but I'm not sure how to interpret it.
Anyone have any insight?
Old Dec 24, 2020 | 01:04 AM
Oxidizer2k's Avatar
Does it create any logs after the crash? That could help the pros here help you figure out why it’s doing that.
Old Dec 24, 2020 | 07:12 PM
AlexJag's Avatar
Sponsor
​​​​​​Maybe try a different version of SDD. I'm using 156 and no issues at all , knock on wood. Are you using a genuine cable?
if you need I can loan out my setup ...
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Dec 31, 2020 | 08:00 AM
Jaizero's Avatar
Sorry for the very late reply.
I am not using a genuine cable, it's the VXDiag VCX Nano found here - https://www.vxdiagshop.com/wholesale...nd-jaguar.html
Software is latest SDD from idscentral.
The error pops up whether the interface is connected or not, on Windows 7 or 10. Literally every other function works except the transmission adaptation relearn. The strange thing is, if I use engineering mode, it seems to work fine. I will try to post the log, but it seems to be a bunch of java call errors.
Alex, can you DM me your rates for tuning? Do you do remote tuning?
2015 XF 3.0 SC AWD
Old Dec 31, 2020 | 10:37 AM
Jaizero's Avatar
Here is the log. Looks like it can't find the adaptation candidate.
com.jlr.sdd.core.SddException: Cannot find candidate: 73655 at com.jlr.sdd.core.sessions.VehicleDiagnosis.getCand idate(VehicleDiagnosis.java:235) at com.jlr.sdd.core.sessions.VehicleDiagnosis.getCand idate(VehicleDiagnosis.java:243) at com.jlr.sdd.tools.ids.pagmcp.actions.PagmcpLaunchA ction.getCandidate(PagmcpLaunchAction.java:137) at com.jlr.sdd.tools.ids.pagmcp.actions.PagmcpLaunchA ction.internalExecute(PagmcpLaunchAction.java:97) at com.jlr.sdd.core.actions.SddDeferableAction.execut e(SddDeferableAction.java:76) at sun.reflect.NativeMethodAccessorImpl.invoke0(Nativ e Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknow n Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Un known Source) at java.lang.reflect.Method.invoke(Unknown Source) at com.opensymphony.xwork2.DefaultActionInvocation.in vokeAction(DefaultActionInvocation.java:404) at com.opensymphony.xwork2.DefaultActionInvocation.in vokeActionOnly(DefaultActionInvocation.java:267) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:229) at com.jlr.sdd.core.actions.SpxInterceptor.intercept( SpxInterceptor.java:80) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at com.opensymphony.xwork2.interceptor.DefaultWorkflo wInterceptor.doIntercept(DefaultWorkflowIntercepto r.java:221) at com.opensymphony.xwork2.interceptor.MethodFilterIn terceptor.intercept(MethodFilterInterceptor.java:8 6) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at com.opensymphony.xwork2.interceptor.ConversionErro rInterceptor.intercept(ConversionErrorInterceptor. java:123) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at com.opensymphony.xwork2.interceptor.ParametersInte rceptor.doIntercept(ParametersInterceptor.java:184 ) at com.opensymphony.xwork2.interceptor.MethodFilterIn terceptor.intercept(MethodFilterInterceptor.java:8 6) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at com.opensymphony.xwork2.interceptor.StaticParamete rsInterceptor.intercept(StaticParametersIntercepto r.java:105) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at com.jlr.sdd.core.actions.SddActionAwareInterceptor .intercept(SddActionAwareInterceptor.java:80) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at org.apache.struts2.interceptor.CheckboxInterceptor .intercept(CheckboxInterceptor.java:83) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at org.apache.struts2.interceptor.FileUploadIntercept or.intercept(FileUploadInterceptor.java:207) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at com.opensymphony.xwork2.interceptor.ModelDrivenInt erceptor.intercept(ModelDrivenInterceptor.java:74) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at com.opensymphony.xwork2.interceptor.ScopedModelDri venInterceptor.intercept(ScopedModelDrivenIntercep tor.java:127) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at org.apache.struts2.interceptor.ProfilingActivation Interceptor.intercept(ProfilingActivationIntercept or.java:107) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at org.apache.struts2.interceptor.debugging.Debugging Interceptor.intercept(DebuggingInterceptor.java:20 6) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at com.opensymphony.xwork2.interceptor.ChainingInterc eptor.intercept(ChainingInterceptor.java:115) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at com.opensymphony.xwork2.interceptor.I18nIntercepto r.intercept(I18nInterceptor.java:143) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at com.opensymphony.xwork2.interceptor.PrepareInterce ptor.doIntercept(PrepareInterceptor.java:121) at com.opensymphony.xwork2.interceptor.MethodFilterIn terceptor.intercept(MethodFilterInterceptor.java:8 6) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at org.apache.struts2.interceptor.ServletConfigInterc eptor.intercept(ServletConfigInterceptor.java:170) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at com.opensymphony.xwork2.interceptor.AliasIntercept or.intercept(AliasInterceptor.java:123) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at com.opensymphony.xwork2.interceptor.ExceptionMappi ngInterceptor.intercept(ExceptionMappingIntercepto r.java:176) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at com.jlr.sdd.core.actions.SddMetricsInterceptor.int ercept(SddMetricsInterceptor.java:31) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at com.jlr.sdd.core.actions.SddTraceInterceptor.inter cept(SddTraceInterceptor.java:23) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:224) at com.opensymphony.xwork2.DefaultActionInvocation$2. doProfiling(DefaultActionInvocation.java:223) at com.opensymphony.xwork2.util.profiling.UtilTimerSt ack.profile(UtilTimerStack.java:455) at com.opensymphony.xwork2.DefaultActionInvocation.in voke(DefaultActionInvocation.java:221) at org.apache.struts2.impl.StrutsActionProxy.execute( StrutsActionProxy.java:50) at org.apache.struts2.dispatcher.Dispatcher.serviceAc tion(Dispatcher.java:504) at org.apache.struts2.dispatcher.FilterDispatcher.doF ilter(FilterDispatcher.java:421) at org.mortbay.jetty.servlet.ServletHandler$CachedCha in.doFilter(ServletHandler.java:1088) at org.mortbay.jetty.servlet.ServletHandler.handle(Se rvletHandler.java:360) at org.mortbay.jetty.security.SecurityHandler.handle( SecurityHandler.java:216) at org.mortbay.jetty.servlet.SessionHandler.handle(Se ssionHandler.java:181) at org.mortbay.jetty.handler.ContextHandler.handle(Co ntextHandler.java:729) at org.mortbay.jetty.webapp.WebAppContext.handle(WebA ppContext.java:405) at org.mortbay.jetty.handler.HandlerWrapper.handle(Ha ndlerWrapper.java:152) at org.mortbay.jetty.Server.handle(Server.java:324) at org.mortbay.jetty.HttpConnection.handleRequest(Htt pConnection.java:505) at org.mortbay.jetty.HttpConnection$RequestHandler.he aderComplete(HttpConnection.java:829) at org.mortbay.jetty.HttpParser.parseNext(HttpParser. java:513) at org.mortbay.jetty.HttpParser.parseAvailable(HttpPa rser.java:211) at org.mortbay.jetty.HttpConnection.handle(HttpConnec tion.java:380) at org.mortbay.jetty.bio.SocketConnector$Connection.r un(SocketConnector.java:228) at org.mortbay.thread.QueuedThreadPool$PoolThread.run (QueuedThreadPool.java:488)
Old Dec 31, 2020 | 04:05 PM
AlexJag's Avatar
Sponsor
2015 XF 3.0 SC AWD
Pm sent
And yes I do remote tuning on regular basis
Old May 4, 2021 | 04:48 PM
PGG's Avatar
PGG
Hi Guys,
Did you had any luck finding what was cauding the
com.jlr.sdd.core.SddException: Cannot find candidate: XXXX
error ?
I am having a very similar problem when trying to update the IMC firmware. The only difference is in the "candidate" number - 53640 in my case.
Running latest SDD (160.04 v342.) in on-line mode with Mongose PRO cable (sourced from Ali...)
Old May 4, 2021 | 06:00 PM
Gus's Avatar
Gus
I am no expert using SDD but I do know that when using SDD I always put a charger on the battery. It seems that it uses a lot of battery power and a low battery voltage could be part of the problem.
Gus
JagRepair.com - Jaguar Repair Information Resource
Old May 5, 2021 | 12:25 AM
PGG's Avatar
PGG
Gus
I use the battery maintainer, and can program other modules without problems.
The error described above appears with or without connection to the car. It seems to be a problem with SDD/PC...
Old May 5, 2021 | 09:26 AM
JagV8's Avatar
I wouldn't even attempt reprogramming without a power supply along the lines specified by Jaguar (55A, low ripple) - a maintainer is nothing like enough.
It doesn't sound like the cause of the current issue, though I wouldn't rule it out.
Old May 5, 2021 | 01:14 PM
PGG's Avatar
PGG
I meant the battery support unit, 13.5V / 65A.
joeleerj
25
Aug 26, 2025 03:21 PM
melhookv12
General Tech Help
51
Nov 29, 2023 08:06 AM
prolepsis
General Tech Help
Jun 2, 2020 05:54 AM
sayitaintso
Jan 29, 2018 07:04 PM
Lagonia
Jan 12, 2014 07:26 AM
