Trickle charger
Old Feb 9, 2014 | 07:59 PM
rredfield's Avatar
Default Trickle charger
Hi extended Jag family, I read a recent post on properly jump starting a Jag and it got me wondering if there is anything special that needs to do when hooking up a trickle charger. I just wanted to make sure before moving foreword, woke up to 11 inches of new snow this morning so it doesn't look like the cat will be back on the road for a while. Thank in advance for helping me answer what is probably a silly question
Russ
2010 XF S/C
Old Feb 15, 2014 | 12:44 PM
sybarite's Avatar
FWIW, couldn't figure out how to get a trickle charger to work on my previous '10 XFR with the usual method of plugging into the 12V socket. Not sure if it had something to do with the design of the electrical system. The only method that worked for me was directly clipping the leads onto the battery.
Old Feb 15, 2014 | 01:04 PM
Originally Posted by rredfield
........... wondering if there is anything special that needs to do when hooking up a trickle charger.
Russ,
Jaguar supply a trickle charger but you can obtain exactly the same type for much less elsewhere. The Jaguar one is a rebadged CTEK.
XF Battery Charger - JAF 0046 (10) 1E.pdf
Regardless of which charger you get, the Jaguar accessory leaflet shows the recommended way of hooking it up.
Old Feb 15, 2014 | 01:06 PM
Originally Posted by sybarite
FWIW, couldn't figure out how to get a trickle charger to work on my previous '10 XFR with the usual method of plugging into the 12V socket. .....
The 12V socket is not live when the ignition is off and the vehicle in 'sleep' mode.
Old Feb 15, 2014 | 01:55 PM
sybarite's Avatar
Mmm. Looks like a bit of a hassle compared to the typical plug and play.
Old Feb 15, 2014 | 04:02 PM
pmarold21's Avatar
I bought a trickle charger at Autozone for $39. Attached it to the battery in the trunk and it works great! I'm not the most mechanical person and it only took me 10 minutes. Worth every penny. BTW, saw the same one at Walmart today for $5 less. Good luck
Old Feb 15, 2014 | 05:03 PM
Mikey's Avatar
Make sure that what you've bought is a battery tender and not a trickle charger. There's a difference.
Old Feb 15, 2014 | 07:20 PM
rredfield's Avatar
Thanks everyone for the input, I guess I should have clarified earlier that it was a battery tender that I have. It sounds like I will be ok with just hooking it up directly to the battery.
Russ
Old Feb 16, 2014 | 11:09 AM
pmarold21's Avatar
Mickey,
You are right. It was a tender I bought, not a trickle charger. Great for the winters.
duecedriver
Dec 25, 2015 11:47 AM
jluckcuck
Nov 6, 2015 07:49 AM
johnr
Oct 27, 2015 02:14 AM
oldjaglover
Sep 29, 2015 03:27 PM
JaguarJoseph
Sep 16, 2015 11:19 AM
