XJ ( X351 ) 2009 - 2019
broken lug studs
Old Mar 21, 2026 | 10:38 AM
JaguarXJL15's Avatar
Default broken lug studs
I recently had two lug studs shear off while mounting and tightening a wheel. Given the failure, I’ve decided it’s safest to replace the entire set on that hub to prevent further issues.
Could anyone advise on the following:
  • Specifications: What are the exact dimensions or thread pitch required
  • Sourcing: Are there preferred brands (like ARP for strength or OEM for fitment) and reliable retailers you recommend?
  • Frequency: Is this a known weak point for this vehicle, or does it typically point to a previous technician over-torquing them?
Any tips on the easiest way to install the new ones myself without a shop would also be greatly appreciated.
Old Mar 21, 2026 | 11:24 AM
wombat's Avatar
M12 x1.5 42mm
wombat
Old Mar 21, 2026 | 11:38 AM
clubairth1's Avatar
Community Influencer
I see he has posted!
Great timing as this was just figured out by another forum member. It seems JLR has stopped listing the wheel studs separately a long time ago. They only sell the entire hub. BUT Wombat looked and way back in the X-Type era JLR did sell them separately!
As always I replace those terrible sheet metal lug nuts with the solid versions. But that will be your choice!
Some can pound out the old stud and install the new without removing the hub. But for me at least on my old 2005 S-Type I removed the hub and used my press. Simple and no damage to either part.
Old Mar 21, 2026 | 04:02 PM
Is this a good price?
Subtotal £40.60 Discount (SPRING SALE) -£8.12 DeliveryDelivery By DHL - International Shipping - CAN £16.25 Vat £0.00 Order Total $89.00 Canadian shipped for 10
  1. C2S50885 - Jaguar Wheel stud
    Wheel stud
    Quantity10
    £40.60
Jaguar Land Rover Classic Parts: This is the most direct source for authentic components. They list the Jaguar Wheel stud as a genuine item built to original specifications.
Old Mar 21, 2026 | 05:53 PM
wombat's Avatar
Looking on-line,
C2S50885 (stud) are available for @$5 each. I'm guessing you will need the nut too. In my opinion, the studs will only break if the have been repeatedly over torqued (or in my case because I cross threaded one due to to much gin!)
You can get them from Amazon, or eBay etc with free shipping.
wombat
Old Mar 21, 2026 | 06:00 PM
wombat's Avatar
One more thought. Given that the stud was used on the X-Type, there must also be a Ford part#. I'm guessing that the Ford part will cost cents, not bucks.
wombat
Actually, I'm wrong! They are about the same price!
Old Mar 22, 2026 | 08:57 AM
clubairth1's Avatar
Thanks Wombat can you post the Ford part number? I will add that to my picture for future use
Old Mar 22, 2026 | 10:31 AM
wombat's Avatar
W706504-S439
wombat
Old Mar 22, 2026 | 06:33 PM
wombat's Avatar
O'Reilly's sell the LR/RR version for @$3.79. Same stud.
Bored of this thread, if you can't use Google yourself, don't expect me to use it for you. It's not difficult.
wombat
Old Mar 23, 2026 | 08:22 AM
clubairth1's Avatar
Thanks for the part number. Was not sure how to cross it over?
Old Mar 27, 2026 | 07:19 AM
There is no way to remove the studs without taking off the hub first. The rust is so severe that the studs look like they're welded on. At this point, it's probably better to just replace the entire hub.
Old Mar 27, 2026 | 07:36 AM
There is one available on rock auto websute it says its for the rear looks exactly the same as the front
TheMark38
Sep 13, 2022 05:15 PM
Byte Me
Jul 9, 2019 10:56 AM
spong
Aug 14, 2014 12:34 AM
JagMaster
Sep 10, 2011 10:37 AM
Markbrown
Sep 25, 2009 04:44 PM
