XJ ( X351 ) 2009 - 2019
Highest Mileage S/C Engines?
Old May 28, 2018 | 08:56 PM
hades281's Avatar
Default Highest Mileage S/C Engines?
Hello! I've got a 2016 F-Type R, so I'm usually hanging out in the other forums. These only came out in 2014, but the engine design seems to date back to '09. I think the XF and XJ have had this engine since its inception.
I'm curious to know if there are some high mileage examples out there and how the engines have held up?
Cheers!
Stephen
Old May 29, 2018 | 10:41 AM
Hank Scorpio's Avatar
mine isnt that high, but im at about 74k, just about time for my 75k service, and everything is going fine. No abnormal oil consumption, no weird noises or behavior.
There are issues with some people's waterpumps though, but I am not sure if that is mileage dependent or not.
Old May 29, 2018 | 05:22 PM
clubairth1's Avatar
Community Influencer
You have a 2016 model 5.0L so it should have the latest 8mm timing chain setup which came out around the end of 2013.
The water pump is on it's 5th part number so be aware of it. It's not an expensive repair plus you should still be under warranty?
Do use the right oil as we have had a number of engine failures.
Old May 31, 2018 | 12:31 PM
XJ8JR's Avatar
I'm nearly at 91k. No engine work ever done, according to the dealer history.
Old May 31, 2018 | 01:00 PM
clubairth1's Avatar
Can you tell us what you have done for oil changes?
Interval?
Dealer done or DIY?
Old May 31, 2018 | 01:15 PM
XJ8JR's Avatar
Interval?
Dealer done or DIY?
If you're talking to me...according to the service history, all oil changes were done at the dealer at intervals that are too long for my tastes. Now that I own the car, there will be DIY oil changes every 3-5k miles. I did the first one right after purchase in January (along with an oil pan gasket repair that the CPO warranty refused to cover) and its nearly time for another one.
Old Jun 2, 2018 | 10:17 AM
clubairth1's Avatar
Sorry yes!
Do you use the drain plug or suck it out?
Interesting as that's the first oil pan leak I have heard of.
I have a 2014 XJR so very interested in your experience.
Old Jun 2, 2018 | 11:06 AM
KingFala's Avatar
Probably doesn't apply to the original question, but an "Oh, by the way" comment; last time in for lube service, they replaced the water pump on my SC-V6. 40,000 miles. Just sayin' .……
Old Jun 4, 2018 | 01:17 PM
XJ8JR's Avatar
Sorry yes!
I let everything drain out old-school style via the plug, then suck out whatever is left (if anything) via the tube just to make sure I get as much as I can out. I know its extra work, but its worth it to me and I don't mind. Actually crawling under old-school style gives me an opportunity to make sure everything still looks good down there.
The pan leak wasn't large enough to cause drips, just some wetness around the seams. It was a very straightforward job using the correct spec gasket. There are a few details in this thread:
https://www.jaguarforums.com/forum/x...-195727/page2/
Old Jun 4, 2018 | 01:54 PM
clubairth1's Avatar
Now that's thorough!
Can't believe any oil would be left in the tube after draining the pan thru the plug?
FloridaJag
197
Jul 15, 2025 10:48 AM
Mhotep
184
Aug 5, 2023 10:55 PM
Car-Nut
Jun 20, 2020 08:18 AM
jagxkrtoofast
Jul 29, 2012 01:03 PM
jobooth321
Mar 3, 2010 12:12 AM
