XJ ( X351 ) 2009 - 2019
What is the best engine flush product for a 2014 V6 supercharged XJ?
Old Feb 23, 2025 | 10:16 PM
Nostyle's Avatar
Default What is the best engine flush product for a 2014 V6 supercharged XJ?
Old Feb 24, 2025 | 08:51 AM
12jagmark's Avatar
Coolant? Oil? Fuel system?
What are you looking for?
And while products are specific to what system they flush, they aren't specific to a vehicle.
You'd probably do best by researching cleaning products for what ever you're looking to flush in the general forum (i.e. overall internet searches) that would give much more info.
Old Feb 25, 2025 | 06:32 AM
Nostyle's Avatar
Default Engine flush as in to clean the engine
Engine flush as in to clean the engine, to flush the chambers and pipes the oil flows through.
Old Feb 25, 2025 | 06:34 AM
Jaaag_drivah's Avatar
If you follow appropriate oil change intervals and use synthetic oil there is no need for this. Oils have detergent additives that perform this function well when changed regularly.
Old Feb 25, 2025 | 10:51 AM
lotusespritse's Avatar
Do a search on YouTube about engine oil flushes. Lots of tests that show they are a bad idea. If you let your engine oil changes go so long that you have sludge throughout, the only hope is to disassemble the engine to clean it, or you will do more harm than good. No magic in a bottle unfortunately. If you don't have sludge buildup, just keep changing your oil with a quality oil with the exact spec for these engines (not just the weight), and change it twice as often as Jag recommends.
Old Feb 26, 2025 | 05:50 AM
Nostyle's Avatar
I wanted to check with the experts along with my internet searches.
Old Feb 26, 2025 | 06:05 AM
OzXFR's Avatar
I agree it's not really needed but if you want to give it a try I recommend BG EPR (Engine Performance Restoration).
It gets good reviews and I have used it (just the once) with zero problems.
When I first got my F-Type way back in 2016 I had no info what the previous owners had or had not done regards oil changes and servicing so one of the first things I did was an oil change and an engine flush using BG EPR. As I said no problems since, who knows if it made a positive difference but it did no harm.
Old Feb 26, 2025 | 09:44 AM
That's my expert opinion. Don't do it. These engines have small passages with variable valve timing just like most modern engines. Knocking sludge loose in big chunks is going to do more harm than good.
lukaluka916
May 2, 2023 08:27 PM
George05
Jul 20, 2022 07:49 AM
jrlpreacher
Sep 25, 2017 05:13 PM
davchr
Apr 20, 2017 08:11 AM
gregg5788
Jan 7, 2014 11:56 PM
