Airbag code 23 ??
Old Jun 25, 2013 | 12:16 PM
dmhippy's Avatar
Default Airbag code 23 ??
This just started when it got hot out.
Start teh car in the morning after it has been in the garage all night and no airbag light.
Get in after work after it has been sitting in the sun all day and blink blink ... blink blink blink... does this a few times then steady on.
Anybody have any ideas where to start ?
Old Jun 25, 2013 | 12:36 PM
jimbov8's Avatar
Have a look under the passenger seat, disconnect the connectors, clean and check then replace and try again.
Hope this helps,
Old Jun 25, 2013 | 03:03 PM
Flash Code 23 = Passenger Seat Side AirBag fault.
For more specific detail, it needs a scantool that can read Body (Bxxxx) DTC codes and PID (Parameter Identification) codes.
Old Jun 26, 2013 | 08:15 AM
ryejag's Avatar
Had that code on mine and found problems with one of the small 4 pin connectors. Contact cleaner helped resolve the problem. Eventually, I did replace the connector when the problem reoccured.
RyeJag
Old Jun 26, 2013 | 09:20 AM
dmhippy's Avatar
Smile
Thanks all, I'll give it a shot over the weekend .
Old Jun 27, 2013 | 12:30 AM
H20boy's Avatar
Come back if you still have issues. My xk8 had a drive side airbag fault that also was only occuring whe it warmed up. I believe i found out why, and i have pics if you need them. The part needing attention is under the leather skin, however.
Old Oct 20, 2013 | 07:11 PM
PatrickO's Avatar
Default Airbag code 23??
Did this get fixed, corrected, rigged, wrecked, stolen, traded....?
Old Oct 21, 2013 | 10:34 AM
dmhippy's Avatar
actually it went away after I simply move the seat a little further forward, guess it was the connector but never got around to fishing for it.
Jpav27
Jul 31, 2022 06:43 AM
Johnken
Sep 15, 2015 05:46 PM
34by151
Sep 6, 2015 05:14 PM
AL NZ
Sep 4, 2015 08:39 PM
