Bad ground?
Old Sep 11, 2019 | 11:46 AM
Wingrider's Avatar
Default Bad ground?
Driving along all seems well, when the dash lit up with a variety of colors.
Went into limp mode, with a variety of electrical issues.
The blower for air conditioning quit, turn signals flashed fast, like a bad bulb.
Trans fault, no abs, no traction control, plus others on dash.
Got it home in the garage, good thing to because now it doesn't want to start
Seems i have read about this type of thing being a bad ground.
Any ideas which one would be helpful when things cool down.
Old Sep 11, 2019 | 07:31 PM
Wingrider's Avatar
Well kids went back out, cooled down the car starts, but still lights the dash up.
Cleaned the three ground points behind the headlights in front.
As well as those in the trunk, with no change.
Still getting the trans fault, no abs, traction control as well as another or two.
Damned headlight wire to hold bulb in fell out getting at lower ground.
The fun just keeps getting better, helpful suggestions appreciated.
Old Sep 11, 2019 | 08:43 PM
motorcarman's Avatar
What DTCs are logged in any/all the modules?
Guessing will not help.
A SINK HOLE is definitely a BAD GROUND!!!!!!!!!!!!!! (get it?)
Old Sep 11, 2019 | 09:43 PM
Wingrider's Avatar
Low voltage on many, & in my haste after the car starting, decided to clear a gang to see what was new.
But being an 04, the icarsoft reader gets NO engine module information, but does read trans, as well as the others
Well not a great idea, as car does not want to start again.
Hooked a battery charger, will see what the morning brings.
The good news, got the wire clip in the headlight assembly back in place, now the headlight parts are back in place.
The three grounding points up front are cleaned & back together, slightly dirtier than those in the trunk, but not badly corroded.
Almost seems like it has to be ground somewhere, with all the lights on at once, but finding it appears to be the problem.
Battery is approaching two years old, so we'll see if charging it makes a difference.
When it gets started again will try to see what codes pop up
Even says i need oil, which it doesn't, W T F
Old Sep 12, 2019 | 03:57 AM
EsRay's Avatar
[QUOTE=Wingrider;2125245
[/QUOTE]
Wingrider, what version iCarsoft do you have? I have LR V1.0 and if I select the Check OBD11 menu, I get the Monitor Overview screen and if I then press Enter again, I get OBD11 Diagnostics? Fully functional?
Old Sep 12, 2019 | 06:57 AM
Wingrider's Avatar
i930 is the model i have Ray, it checks all sorts of things, even the stereo.
Reads the eight parameters, for the check engine light, as they all do.
Went out an hour or so ago, the car started right up, after charging the battery overnight, the lights went out..
So did cleaning the grounds, up front, & in the trunk, & then charging do the trick, is my battery on the way out, or do i have another issue?
Time, & driving will tell, i will check the voltage output when the charger finishes its job.
Old Sep 12, 2019 | 07:53 AM
abonano's Avatar
Battery for sure
Old Sep 12, 2019 | 10:46 AM
Wingrider's Avatar
Came to the same conclusion, after 12 hrs on charger then starting, lights cleared, charger back on for a couple hrs.
With a reading of 12.08 volts with just a regular volt meter, battery is toast, less than two yrs old.
Appreciate all the help, and input from out there, Thanks
Old Sep 12, 2019 | 10:51 AM
Mark in Maine's Avatar
Or if the grounds were that bad, it could have affected the charging. Check charging voltages both at the battery and if you can at the alt after recharged. I'm still chasing charging/drain issues that only happen in the winter when it gets really cold overnight. My Ctech overcomes the issues, but is not the cure. This is with a new battery fully charged.
Old Sep 12, 2019 | 09:30 PM
Wingrider's Avatar
Looks like i spoke too soon, at 11.86 v, alternator isn't putting out enough.
I switched battery into the other Jag, & it charged right up.
The good 07 battery into the 04, charged at 11.86, same as the other battery
Have another alternator, & starter, looks like the time to install them.
Old Sep 13, 2019 | 02:18 PM
Wingrider's Avatar
Starter, & alternator, both installed, big cats back on its feet, ready to run with full electrical power.
Peter Garrod
General Tech Help
Jan 17, 2014 11:29 PM
GonzoJag
47
Feb 10, 2013 11:12 AM
relinuca
Nov 11, 2010 11:31 AM
