Boot badge and trunk release button refresh
Old Mar 26, 2019 | 07:20 AM
310jag's Avatar
Default Boot badge and trunk release button refresh
The years have taken a toll on my boot badge and trunk release button, so I decided to clean them up a bit. I had some extra gloss black enamel model paint laying around, and sourced a replacement button from ebay for a very fair price. A little time invested and I'm very happy with the results, just thought I would share.
Looking pretty sad
Border taped off
Filled in
Tape removed, then letters filled in by hand. A toothpick with one end cut to a wedge shape works excellent for cleaning up any coloring outside of the lines.
Not bad for $0.
Definitely seen better days
Remove the retaining clips from trunk lid liner, and black plastic shroud around latch.
Plinth comes off by removing now accessible six 10mm nuts and some gentle prying.
Release button is held in by two small phillips screws.
New 25mm button, slightly larger than the old. Some trimming will need to be done. It comes backed with a high quality 3M tape.
Release the three equally spaced tabs to removed the button base.
Base and spring.
Peel the old button face from the base and clean the surface thoroughly.
I've etched a pencil line where the ring needs to be sanded back to. I used a wide metal file, but a dremel, sandpaper, or careful handled razor knife would do the job.
The button base now sits proud of the trim.
Button face fitted
Final product
Old Mar 27, 2019 | 03:05 AM
Datsports's Avatar
Nice Results actually !
Old Mar 27, 2019 | 09:37 AM
Sochi2014's Avatar
Looks cool!
Old Mar 27, 2019 | 11:24 AM
stham's Avatar
Excellent work. I like that new badge. You've convinced me to do this.
Old Mar 27, 2019 | 05:08 PM
abonano's Avatar
+1 very nice work
Old Nov 2, 2020 | 08:45 PM
SlateXKRcoupe's Avatar
Would anyone happen to have one of these in red hanging around I could pay you handsomely for ? Seller doesnt have red available any longer
Old Nov 3, 2020 | 10:08 AM
aceler8's Avatar
Kudos for going the extra mile, but i ordered the same trunk button in orange and just taped it on top of the faded OEM button. Your button looks a bit better fit-wise, but it would be hard to see the difference and this route took 1 minute and looks fine. Thanks for the pictures and documenting it.
Old Nov 4, 2020 | 04:59 AM
meirion1's Avatar
Amazing what you can do with some rubbing compound and cotton buds.
Old Nov 4, 2020 | 06:44 AM
JoeDredd's Avatar
I think a quick wipe with paint thinners cleans the surface off. Dont touch it for a few mins as it can leave the surface a bit tacky. And thanks to th OP for this as i need to replace my melty number plate light holders and those pics help a lot.
Old Nov 5, 2020 | 08:35 PM
Brewster411's Avatar
I used isopropyl alcohol to clean up the trunk button and it worked very well. Paint thinner should work about the same way I would think.
Old Nov 5, 2020 | 09:08 PM
Mark in Maine's Avatar
Just received my new green button cover from one of our listed vendors has a direct replacement button. Welsh Ent. Received mine today. No more black hazy sticky button for me. Looks black and silver until light hits it a certain way, then shows the green background.
JagNoir
Dec 29, 2024 03:40 PM
pk4144
Oct 23, 2020 05:32 AM
05XK8cfe
Aug 22, 2020 12:48 PM
Someb
Jun 11, 2019 10:11 AM
Wes_R
Detailing / Car care
Sep 6, 2013 05:54 PM
