Boot lid wont close
Old Nov 12, 2019 | 01:28 PM
BDuncan's Avatar
Default Boot lid wont close
Help please. I have had to jump start my Jaguar XJ6 X350 and now the boot lid wont close. Can anyone help.
Old Nov 13, 2019 | 02:16 AM
JX350's Avatar
Hi Bruce,
Have you just tried to press the boot release button (on the boot or in the cabin) and then try to shut the boot. It might just think the boot is already closed and has engaged the mechanism.
Thanks,
Chris
Old Nov 13, 2019 | 07:39 AM
BDuncan's Avatar
JX350,
I tried to close the latch with the boot open and it worked. But when I then opened the boot catch via the boot release button (on the boot or in the cabin) the latch opened but when I tried to close the boot it wouldn't latch. Would this have anything to do with my other issue with low battery power ?
Old Nov 13, 2019 | 09:51 AM
JoeDredd's Avatar
Is the boot lock asm making the locking noise when you close it? It should whir and pull it closed when you drop the lid if it isn't then you may have a dead boot latch mechanism. When I broke mine I had a slight panic that I couldn't close the boot but a good slam solved it. A replacement latch mech fixed it about £75 on ebay.
Old Nov 13, 2019 | 09:57 AM
BDuncan's Avatar
Joe Dredd,
No its not making a noise when I close it. Will have a further look at the latch tonight.
Thanks for your help.
Old Nov 13, 2019 | 10:29 AM
JX350's Avatar
Hi Bruce,
I wouldn't do anything with the boot problem until you've checked the battery. You might be wasting your time and money looking at a problem that does not exist if it's a problem with the battery or alternator.
Thanks,
Chris
Old Nov 14, 2019 | 08:26 AM
BDuncan's Avatar
Got it, forget boot lid. Car in with auto electricians will let you know result.
Thanks.
Old Nov 14, 2019 | 09:33 AM
JX350's Avatar
Hi Bruce,
Hopefully it will be something simple causing all the problems.
Cheers,
Chris
Old Nov 14, 2019 | 06:59 PM
meirion1's Avatar
Probably needs a replacement actuator
Old Nov 15, 2019 | 03:05 AM
BDuncan's Avatar
Meirion1
I have just got my car car back from the auto electrician and been told all my Boot lid issues are being cause because of no battery power due to the alternator not charging the battery. He charged the battery and the boot lid catch opened and when I put the lid down it worked Fine. Awaiting arrival of new alternator on Monday and will fit it on Tuesday. Hopefully end of issues.
Thanks very much for your help folks.
Old Nov 16, 2019 | 10:47 AM
JX350's Avatar
Hi Bruce,
So it was a battery problem caused by the alternator. Glad you got it sorted. At least now you don't have to worry about fixing anything else as it was related to the battery condition as we suspected.
Thanks for the update.
Cheers,
Chris
Old Nov 21, 2019 | 02:09 PM
BDuncan's Avatar
Meirion 1
New. Alternator fitted. All issues resolved.
Old Nov 21, 2019 | 02:11 PM
BDuncan's Avatar
JX350
New alternator fitted. All issues not fixed. Thanks for your help folks.
Old Nov 21, 2019 | 02:12 PM
BDuncan's Avatar
Joe Dredd.
New alternator fitted and all issues fixed.
Old Nov 21, 2019 | 03:16 PM
JX350's Avatar
Thanks for the update Bruce and thanks for letting us all know. At least you didn't spend too much time hunting for issues that did not exist and caused by low battery due to the alternator. Glad it's all back up and running.
manycars
Dec 3, 2024 10:25 AM
Maverick76
Jul 24, 2023 06:52 PM
joebit
Oct 24, 2020 04:11 PM
Billsblue73
Jan 3, 2014 05:47 PM
Norm 427
Jan 20, 2013 01:39 PM
