Coolant
Old Jul 4, 2020 | 07:26 AM
romroc's Avatar
Default Coolant
What is correct coolant 04 xj8?
Old Jul 4, 2020 | 08:39 AM
motorcarman's Avatar
Info for you.
File Type: pdf
Old Jul 4, 2020 | 08:42 AM
NBCat's Avatar
Use coolant that is described in the TSB above. Easiest OAT coolant to locate is DexCool, which also meets JLR specifications.
Old Jul 4, 2020 | 09:01 AM
romroc's Avatar
Thank You. My parts supply lookup says Dex Cool byiby Preston's not recommended.
Old Jul 4, 2020 | 09:02 AM
abonano's Avatar
I suggest you find a new parts supply look up. Dex Cool is 100% compatible
Old Jul 4, 2020 | 09:06 AM
romroc's Avatar
I think you are right. OAT is the key. Another site confirms.
Old Jul 4, 2020 | 10:11 AM
clubairth1's Avatar
Community Influencer
Correct use Dex Cool.
Old Jul 4, 2020 | 11:49 AM
Clapton7's Avatar
Well, dear Mr. romroc...
For almost 5 years I'm using this "Prestone 50/50 fluid" on my XJ8, 3.6L y2007
to my complete satisfaction.
But... it is up to your private decision.
FYI.
P.S.
From today's car inspection, my "iCarsoft" Diagnostic Tool scanner reports:
Engine coolant temperature ----- 91°C and 5-6 min. later:
Engine coolant temperature ----- 92°C
Old Jul 4, 2020 | 01:53 PM
romroc's Avatar
Thanks!
Old Jul 4, 2020 | 01:55 PM
romroc's Avatar
It appears that an OAT coolant is called for.
Old Oct 31, 2020 | 04:05 AM
stuhillman's Avatar
As far as the coolant type, I bought a 5 litre bottle direct from the Jag dealer. Part number JLM209723. Probably paid too much but, at least, no problem with the dealer saying "you might have used the wrong coolant." The problem with losing coolant has finally been solved. They did an overnight pressure check on the system and finally determined that there is no internal leak. The problem seems to have been a faulty pressure cap allowing steam to escape and eventually lowering the fluid level. Simples! By-the-way, fuel consumption, in Europe, is measured as so many litres per 100 kilometers. Now that the engine is running at the correct temperature with proper pressure maintained there has been an immediate drop in fuel consumption by about ½ litre per 100 kilometers. My old XE diesel used about 5.5 liters per 100 kilometers, my XF AWD with the same diesel engine averages about 6.5 litres per 100 kilometers and my new XE with the 250hp petrol engine is at 8.0 litres per 100 kilometers - a significant increase in running costs but, in my opinion, well worth it for the super performance. It's a very satisfying, very quick car.
aeginc77
Mar 10, 2021 04:06 PM
nsl1
Nov 27, 2015 10:55 AM
newjagowner
Oct 5, 2012 04:44 PM
JagManBonano
Sep 5, 2012 05:59 PM
plums
Jul 8, 2011 01:33 AM
