difficult starting solved 2004 xj8
Old Mar 2, 2018 | 03:43 PM
romroc's Avatar
Default difficult starting solved 2004 xj8
Changed out crank pos. sensor, (CPS). Jack up front, 27mm torx, disconnect wire, straightforward. I would now say that @ 100k US mileage, just change it? I would. It was lightly corroded, looks vulnerable to water, dirt, etc. Bonus: MPGS are up by 2. Performance is insane, and they made a blower version? I am now exceedingly delighted. Talking xj here, know what I mean? Quite a ride, cosmetics are due for care, will have some tea now.
Old Mar 2, 2018 | 04:33 PM
Victor Marquez's Avatar
do you have a part number?
Old Mar 2, 2018 | 04:59 PM
romroc's Avatar
Rockauto, I bought their last Beck Arnley part. Airtex Welles #5s1754 is available, will work. Point is, this part can go, causing trouble aplenty.
Old Mar 3, 2018 | 03:25 PM
jackra_1's Avatar
Were you getting any error codes?
Old Mar 3, 2018 | 03:56 PM
romroc's Avatar
None. Old part didnt look too bad. If you know the xj8 350, you know that its a bad boy in sheeps attire.
Old Mar 3, 2018 | 03:58 PM
jackra_1's Avatar
I have the XJR. I will be under it next week so may as well replace this part while I am at it. Cheap enough.
Old Mar 25, 2018 | 07:46 PM
ayavner's Avatar
What were the symptoms?
Old Mar 26, 2018 | 07:39 AM
romroc's Avatar
hard starting x350, 2004.2004 xj8 exhibits good cranking but occasionally very long cranking times. Low outside temps a partial factor. Land Rovers also can exhibit this problem, did not test sensor as it is underneath vehicle, once vehicle supported, one torx bolt (27) holds it. Now everytime car is cranked starts right up, warmup is stronger also. Very, very relieved, car now reliable, my wife can take it to the gym, shopping, etc., without fail. Seen these as low as $13 US, @ Rock Auto, cheap shipping rates.
Old Mar 26, 2018 | 02:46 PM
hisport's Avatar
Rom
Did it ever throw a code?
Suggest you clean grnd studs behind RH headlight as well (esp bottom one)
john
Old Mar 26, 2018 | 04:16 PM
romroc's Avatar
Originally Posted by hisport
Rom
john
had some unexpected starting trouble today (arrrg!) Will look it those grounds for sure.
alan924
Aug 9, 2017 07:43 AM
DaveGT84
Jul 6, 2017 05:11 PM
RDMinor
May 12, 2013 02:31 PM
