Disable Steering Wheel Lock with SDD
Hi.
Yes I have and found nothing useful.
J
As far as I know, a steering wheel lock is mandatory by law in most countries as a basic safety measure against theft and as such it would not make sense for Jaguar to include a disabling feature into SSD. Also, I know that if a car has been stolen and found with damage, insurance will not pay if it comes to light that the steering wheel lock had not been inserted, which was something you had to make sure of with the older mechanical types.
I have not used SSD for some time now, but I do not remember seeing such a feature, be it V125 or V131.
Out of curiosity, why do you want to disable it at all? I actually have the habit of making sure that it is inserted when I park one of my cars...
Best regards to your beautiful country (I have been there a few years ago),
Thomas
Thomas
Thomas
Thomas
Thanks again for your proposals and observations.
Ah! The issue is that the car won't start, not that the steering wheel won't unlock. It's not the steering lock that is preventing it from starting. Whatever is preventing it from starting is what's keeping you from being able to unlock the wheel. You have cause and effect out of order.
My money is that the ignition switch is not detecting your key properly. As for what to do about it, I have no clue, but I do know that the surround of the ignition switch has an antenna to read the key's transponder. If it fails, then no start.
Usually I get no codes but this time I have U2195.
Program the IP as new. If SDD doesn’t ask you the right questions use IDS..When it’s programmed as a non column lock instrument cluster you unplug the column lock module and you’re basically the same as an american car.
I’ve never heard of bad pats rings or bad keys on these cars, 99% of these complaints come from europeans who have sclms
Thanks a bunch!!
Bluefish001
Oct 9, 2022 06:09 PM
Aarcuda
Oct 20, 2020 08:51 PM
