Door speaker failure
Old Feb 26, 2012 | 09:29 PM
gmcgann's Avatar
Default Door speaker failure
I tackled my non-functioning door speakers today in my '04 XJR. Both right door mid-bass speakers were out although the tweeters were working. The wiring diagram shows both these speakers run off the same channel on the amp so I figured it was the speaker.
The door panel gave me some trouble. It was actually very simple, 4 screws and pull it off, but I wasn't expecting to have to use as much force as I did. I don't know if the panels were stuck because they've never been off before, or if they are just that tight, but I stopped several times to consult the workshop manual and make sure I had all the screws out. My trim tool wouldn't do it and I finally worked up to a pickle fork before it popped off.
I tried another speaker and it worked, and I had read in another thread that the connections in the speaker itself go bad sometimes, so I jumped a wire from the input directly to the wires going to the voice coil and it worked. I took both speakers and soldered jumper wires to the voice coil leads and everything seems good now.
Old Feb 26, 2012 | 09:57 PM
jahummer's Avatar
Glad it worked for you. Also see you too have Alpine's top of the line DD drive speakers.
Old Feb 27, 2012 | 06:55 AM
kaug23's Avatar
I fixed all four of mine in December the same way. This seems to be a problem on all of these speakers. Mine were corroded between the soldered connection and the point where they were glued to the stand-off. I assumed it was the solder they used, but someone else suggested it may be the glue instead.
Old Aug 2, 2015 | 11:25 AM
xylorex's Avatar
Default completed my speaker repairs yesterday
I finally had a chance to do this to my speakers yesterday. Over time all four of my door speakers had stopped working. just like kaug said "Mine were corroded between the soldered connection and the point where they were glued to the stand-off." the copper wire was corroded at the standoff.
the door panels in my x350 are the highest quality and design i've ever seen! i was nervous until i got the first one off.
thank your for the starting this thread and posting the pic gmcgann.
Old Aug 2, 2015 | 12:42 PM
roviw's Avatar
Hi, you mentioned only 4 screws to hold the door panel in, I have a rattle in the door as if something has come unclipped, it knocks over bumpy ground so I want to remove the panel and take a look, are the screws easy to spot or are they hidden please. Many thanks
Old Aug 2, 2015 | 01:38 PM
xylorex's Avatar
on my 2004 vanden plas there is one screw behind the inside door handle, below the tweeter. it is hidden behind a small plastic plug. you will need a torx bit for this screw.
there are two philips head screws below the door pull handle
there is one plastic clip on the very bottom of the panel, on the hinge side of the light. unscrew the plastic philips head screw 3 or 4 turns and the clip will pull out.
Old Aug 2, 2015 | 04:16 PM
roviw's Avatar
xylorex, that is most helpful thanks, I will look at doing the job next weekend, cheers
Old Apr 17, 2016 | 07:33 PM
Florida_Pilot's Avatar
Just did the same thing in my VDP and brought two dead speakers back to life! Great tip - thanks!
Old Apr 18, 2016 | 05:14 AM
clifton94's Avatar
Nice bit of info thanks
Old Mar 22, 2020 | 07:23 PM
Brewster411's Avatar
FINALLY got around to doing this. Three of my door speakers were not working and had not been working since I purchased the car three years ago.
I fixed all three of the speakers using this technique. Man, this system sounds amazing! Feels like a brand new car now.
Old Apr 11, 2020 | 01:24 PM
Donny Williams's Avatar
My two back door(s) rears main speakers are not working but the tweeters are (2005 Super) Any trick to the rear door panel removal? As with many do not want to screw anything up. But I suspect this is my problem too. Seems there is allot of these cars that have this same exact problem. Thank you GMCGann for the post!
Old Apr 11, 2020 | 08:44 PM
https://www.jaguarforums.com/forum/x...repair-132821/
This is for front door panel removal, but the rear door panel is very similar. Once you remove the bolts, I found that starting at the bottom of the panel near the speaker is the best way to release the plugs. If you look at the pics, the green things are where the plugs go that you will need to release.
Note that the picture does not show that you have to remove a plastic plug at the bottom center of the door.
Old Jun 6, 2020 | 10:39 AM
Gregarious's Avatar
Thank you. Worked just perfect. Now have all speakers working. The dash pad speaker reinstall resulted in the trim panel sort of self-destructing I think due to age. i used very little pressure to reinsert it. Best source for a replacement? It is the left side and is a tan color. (2006 VDP)
Old May 24, 2023 | 09:49 PM
skywarrior's Avatar
There actually two Phillips head screws on the bottom of the door panel on a 2007 VDP.
Old May 23, 2025 | 04:10 PM
Cobalteer's Avatar
Default Thanks for this great tip
Just brought two of my non functional door speakers back to life exactly as described. A no-cost fix is so rewarding!
jwburch21
Jun 21, 2019 03:54 PM
AltonJag
Jul 2, 2018 04:08 PM
BlackX300VDP
Apr 2, 2015 01:09 PM
Mago304
Nov 28, 2008 02:20 PM
