How to program Climate Control Module
Old Nov 18, 2018 | 05:44 PM
  #41
Mike-Ko's Avatar
Yes my car came without screen and I got the harness, navigation control module and screen.
After I installed them, they works fine but not the climate control. I can not control my climate. I think it’s just happened like you before.
so if I replaced the climate control module that is under the dashboard into a ccm that was from a xj8 that equips Nav, will it work?
Originally Posted by joeleerj
If your car was a non-touchscreen originally, you will need a wire harness like the one I got from a, Jaguarforum.com, member ,jostaffs, a sat/nav module for the trunk and a way to program the modules.
Old Nov 18, 2018 | 05:55 PM
  #42
joeleerj's Avatar
In the end , I didn't need to replace my CCM. I just used my SDD to tell the car it had navigation. After which everything worked fine. You should be able to do the same. Do you have SDD or IDS available?
Old Nov 18, 2018 | 09:19 PM
  #43
Mike-Ko's Avatar
Unfortunely, I dont have any of them. That 's why I am thinking about replace the CCM
Old Nov 18, 2018 | 09:48 PM
  #44
joeleerj's Avatar
That won't work, because you will still have to program it to work with your car. It's VIN specific and your VID block has to recognize it.
Old Nov 19, 2018 | 02:59 PM
  #45
stham's Avatar
You can use SDD to program any module in the car, I made a thread a while ago about my climate control system bugging up and acting like it was a system from an X-type. I chose MANUAL reconfigure of either the amplifier or some other module (i forget). Selecting Manual allows you to select vehicle specific features which then writes into the ECM's VID memory.
Old Nov 20, 2018 | 05:58 AM
  #46
Mike-Ko's Avatar
I went the dealer today, they told they can not do that for me.
So i have to get the SDD system from ebay. But how that works? I mean all I need is the software, latop and OBD2 cable that connect the latop to my car?
Old Nov 20, 2018 | 06:43 AM
  #47
stham's Avatar
There are numerous threads about this topic and what you need. But all in all your basic understanding is correct.
You need an XP based laptop (or one that runs XP on virtual machine) you need a compatible OBD2 cable (Mongoose or equivalent) and the SDD software.
As long as you know your way around a computers its rather straight forward. The software itself is dimwitted and slow; and will freeze up occasionally.
If you are doing any ECM/TCM reflashes, its usually recommended you source a HIGH QUALITY power supply such as ones used with RF radios, as they produce stable voltage with little noise
Old Nov 23, 2018 | 04:34 AM
  #48
Mike-Ko's Avatar
I've got a SDD today but I have no ideas how to use this for reprograming.
Actually I am not good at this, can you let me know few little quick steps? I just wanna make my touchscreen works on climate.
Old Nov 23, 2018 | 07:46 AM
  #49
jackra_1's Avatar
https://video.search.yahoo.com/searc...70&action=view
Have a look at the above to begin with.
I suggest you do NOT try any reprogramming until you have done a lot of research and then only with an approved battery support product as already mentioned.
Old Nov 24, 2018 | 08:47 AM
  #50
Mike-Ko's Avatar
The problem solved. I used SDD to add climate module and secleted the Manual then just set NAV "fitted".
Now works perfect.
Thank you guys.
Old Aug 18, 2019 | 04:29 PM
  #51
Kip's Avatar
Kip
Finally got it up and running, thanks to the wire harness supplied by jostaffs, over on the jaguarforum.com, and the help of motorman and Sean W on this forum. Turns out, the XJR's CCM does not need to be replaced, just tell the car that is has navigation. U wish I had taken pictures of the process, however, I'm willing to review the process I used and provides the details to anyone interested. I know that this SAT/Nav system is outdated, but I like the way it looks in my car. Thanks so much..
i want to take my navi out so I have to reverse the process you've done.. Can u tell what parts I need to get and what needs to be done
Old Aug 18, 2019 | 04:37 PM
  #52
jackra_1's Avatar
From your other thread I see that you want to install an aftermarket unit.
That being so you have to follow the directions that come with the after market unit.
I must admit I do not understand your objective?
Old Aug 18, 2019 | 06:32 PM
  #53
joeleerj's Avatar
Since I started with a non-navi system, all I had to do was install additional wiring and program. Like jackra_1 stated, you should follow the aftermarket instructions, since you won't be using the fiber optics.
Old Aug 19, 2019 | 07:19 AM
  #54
Kip's Avatar
Kip
I'm trying to install a button style control panel for climate control, then after market stero...need wiring info for panel
Old Aug 19, 2019 | 08:06 AM
  #55
jackra_1's Avatar
Are you talking about the above type of installation?
Old Aug 19, 2019 | 05:12 PM
  #56
Kip's Avatar
Kip
Originally Posted by jackra_1
https://www.youtube.com/watch?v=U4HpklUXZCs
Yes yes yes
Old Aug 19, 2019 | 05:15 PM
  #57
jackra_1's Avatar
Ok now I understand.
You need the wiring diagram for that type of head unit and I am not sure what model that is.
For starters have a look at this: https://www.jaguarforums.com/forum/x...others-101568/
Old Sep 19, 2023 | 05:35 AM
  #58
Nord_Steel's Avatar
Originally Posted by Mike-Ko
Проблема решена. Я использовал SDD, чтобы добавить модуль климата, выделил Руководство, а затем просто установил NAV «установлен».
Теперь работает идеально.
Спасибо вам, ребята.
Friends, I put a monitor instead of a "calculator". I laid an additional wiring harness to connect the navigation unit. I pulled the optics connector out of the changer and inserted it into the navigation unit. The changer does not work because there is not enough optical connector. But it doesn't matter, because I have a Bluetooth module instead of a CD. That is, my monitor is working now, but I can't adjust the climate, it doesn't respond to the buttons. Sound, radio, navigation are working. The question is, in which section of the SDD should the navigation unit be registered in order for the climate control to work?
XJ x350
Buttcrackplumber
Apr 16, 2019 06:57 AM
Maddashimports
Nov 11, 2017 05:44 PM
RobbyHughes
Mar 8, 2016 07:46 AM
worldrider
Aug 11, 2015 07:31 AM
l17led
Jan 20, 2010 07:32 PM
