need nav disk info please
Old Aug 22, 2011 | 09:46 PM
Jsedita74's Avatar
Default need nav disk info please
ok so i have what i assume is the original nav disk which is waaaaaaaay outdated here in NY and is driving me crazy... So my question is this.. Which is the current and latest disk aaaaaaaaaand (here comes the kicker) can I burn a copy and will it play and function properly? I am NOT paying 100$+ for this disk.. Is any other car navi disk compatable? maybe some ford cars or something? Thanks chaps
Old Aug 22, 2011 | 10:46 PM
Jsedita74's Avatar
ok so I tried a little experiment and burned a copy of the nav disk onto a dual layer dvd .. The burn looked like it completed properly and there were no errors but when I put the disk in it gives an error saying " insert map disk" .. Now why wouldnt it read the disk? I dont get it.. Does anyone know the type a media they use to make these disks ? I used a dvd+r dl. maybe its dvd-r dl? any clues or ideas?
Old Aug 23, 2011 | 08:29 AM
amcdonal86's Avatar
Do a search for "navigation map dvd". I'm not sure what the answer to your question is, but I know that the car is very sensitive to even the brand of DVD disc you use.
Old Aug 24, 2011 | 06:30 AM
rick1965's Avatar
i got a new nav. disc a couple of months ago at my dealer.
Old Aug 24, 2011 | 09:32 AM
kthrash's Avatar
You have to use Verbatim DVD+R DL 8X discs burned at 1X on a Pioneer DVD Burner..
Old Aug 24, 2011 | 03:20 PM
u102768's Avatar
I have used TDK DVD-R's burnt at the fastest the drive will go with no problems.
I suspect it has more to do with the defaults of the package used to do the burning and the options chosen.
I use Roxio Creator Basic.
Old Aug 24, 2011 | 07:30 PM
jahummer's Avatar
2010 is the latest and the best (it also comes with a small firmware update for your headunit) but I understand that a 2012 should be coming in October.
Oh, and no there are no other discs that will work, other brand vehicle wise. These are made specifically for these heads units/vehicle models. The good ness is you can sell your old disc on eBay!
Old Aug 24, 2011 | 08:02 PM
Jsedita74's Avatar
What do these disks cost and how often are they updated?
Old Aug 24, 2011 | 08:33 PM
u102768's Avatar
I agree that there are probably no other brands that will have the correct update firmware but if you don't need to update it there are a number of other vehicle nav DVD's that should work.
The maps from my X350 work in my wife's Subaru and I have also used a Toyota sourced map disk in mine.
Old Aug 24, 2011 | 09:09 PM
jahummer's Avatar
Interesting info as I never had luck with swapping discs between Jag models. Also if I am not mistaken, the head unit is made by Toyota as are many other electronic components in our cars!
The discs are only a couple hundred bucks from Navtec the actual manufacturer for nav discs and they are not worth updating annually as the changes can be fairly minor. I have the 2010 and looking forward to the 2012.
Old Aug 25, 2011 | 03:30 AM
u102768's Avatar
Manufacturers tend to share parts across model ranges so you will find that the S and X Types of a similar vintage to the X350 have the same nav unit. Discs can be switched between the new XK and XF as well.
The basic structure of the data on the nav disc is defined by a consortium of different electronic companies which is why some discs can be used in multiple cars.
Kiwi-W Consortium
The units are made by Denso which is a member of the Toyota Group so I guess you could say Toyota make them! The EMS, fuel injectors and air-con compressor are other Denso items on the X350.
I wonder if there will be an new features and firmware released.
Old Aug 25, 2011 | 09:07 AM
c3r3br0's Avatar
I ordered the disk it was around $220 after shipping and taxes. I should have just did it through the dealer, they had a special for $199.99. I could have saved $20.
Old Aug 25, 2011 | 09:42 AM
kthrash's Avatar
I wasted many brands of disc's trying to duplicate and after much research/time and failures have found that my statement above typically yields a flawless disc 99.99% of the time.
I use Roxio Toast Titanium on a Mac with a SuperDrive to burn mine..
Old Aug 27, 2011 | 05:14 PM
Jsedita74's Avatar
thank you sir !!!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 29, 2011 | 01:37 PM
danimo's Avatar
Banned
Default disk
Old Aug 30, 2011 | 10:02 PM
prelude4ws's Avatar
Default is firmware upgrade optional?
when going to a newer disk is the firmware upgrade optional upon intallation or is it mandatory?
Old Aug 31, 2011 | 12:36 AM
Jsedita74's Avatar
Totally mandatory . I had zero control over it. As soon as I turned the car on and put the disk in it went into auto pilot which is cool with me. I can't see a firmware update being bad for us. I did notice that when I had the screen on the jaguar logo screen it was green and now somehow it's black... I kind of liked the green but otherwise the only thing I notice is that it added daytime running lights ... Also the screen seems a bit clearer then before...
Old Aug 31, 2011 | 05:01 AM
u102768's Avatar
It depends how much effort you want to go to.
When you insert a map disk the nav unit checks what version it is. If it is later than the currently running firmware it will look for a file called loading.kwi. If it finds it, it loads it and that is how the firmware gets updated.
Not all map disks have the file on so if for some reason you didn't want to update your firmware you could copy the files off the new nav disk on to a PC, delete loading.kwi then burn them back on to a new DVD.
That assumes that the new firmware isn't required due to a fundamental change to the map data.
There is also a button in the nav units hidden diagnostic menu call 'Auto S/W update'. If you press it, the button surround turns red so this may be a way of turning off the auto update. Unfortunately it only lasts for one igniton cycle so would be a bit labour intensive to use it all the time!
Not sure why you would want to do any of this anyway but in theory it is possible.
Old Aug 31, 2011 | 05:21 PM
prelude4ws's Avatar
the only reason I would prefer not to upgrade is that I don't care for daytime running lights.My car (04 xjr) came without the disc(have no idea what version is on it). I have been slowly trying to get my system in working order as the c-pillar water leak(before I purchased) took out the amplifier and dvd player, while the navigation and cd changer seem to be operational and interior free of water stains. But I digress..
Old Aug 31, 2011 | 06:10 PM
u102768's Avatar
The upgrade just adds a button in one of the menus that allows you to alter the default for the daytime running lights. I think the default is off anyway so it won't affect you.
Finbarr1975
Sep 5, 2025 08:38 PM
Paora
Feb 4, 2021 12:36 AM
Finbarr1975
Oct 4, 2015 05:32 PM
10 XF Premium
Oct 2, 2015 09:22 PM
inactualis
Oct 2, 2015 11:13 AM
