Rear parking sensor R&R?
Old Jan 15, 2018 | 09:15 PM
electechbw's Avatar
Default Rear parking sensor R&R?
So, I'm getting a long beep when I put my car in reverse. I found some advice on line and found that one of my sensors isn't "ticking"? I'd like to swap that one with an adjacent sensor for test purposes. Question is... How do I remove it? I saw on a different model that the bumper needs to come off, but what about the X350?
Old Jan 16, 2018 | 05:40 AM
magmedia's Avatar
https://www.jaguarforums.com/forum/x...cement-172957/
Please see the link above for some reference photos.
Thanks.
-mag
Old Jan 16, 2018 | 06:54 AM
electechbw's Avatar
That's perfect! Thanks a bunch!
Old Jan 16, 2018 | 05:19 PM
djpxk8's Avatar
I have just changed the rear parking sensor on my 2004 XJ8 VDP and had to take off the rear bumper, not too difficult a job.
Old Jan 16, 2018 | 06:55 PM
JBzXJ40's Avatar
You can use a stethoscope without the rod in the end of the hose.
Place the end of the hose over each sensor - with someone in the vehicle, and placed in reverse, you should hear a high pitched ticking noise, if not, that's your dead sensor.
Old Jan 16, 2018 | 07:47 PM
electechbw's Avatar
I found the bad sensor by just turning the key to the run position (engine off), putting it in reverse, and putting on the parking brake. Then I just walked to the rear bumper and put my ear next to each sensor. They were all ticking except for the rightmost one. Now, I just need to figure out if it's the sensor itself or the wiring.
Old Jan 21, 2018 | 11:03 AM
06-XJR's Avatar
Just buy a new sensor, 99% chance that's the problem, unless you've been hit in the bumper or something. I paid something like $17 from eBay for my replacement sensor (direct fit aftermarket).
Old Jan 21, 2018 | 02:06 PM
Sean W's Avatar
Yeah you're going to be unpleasantly surprised at how much crud is under that bumper cover. I'm never a fan of swapping parts based on assumptions, but if it's your daily driver, you might want to have a sensor on hand or your car will have to sit until you get one shipped to your home.
Also, unless you find a used one that's color matched to your car, you'll need to paint it, so pick up some Jag touch up paint too. I think I read a thread where someone was able to replace the end sensor without taking the bumper cover off but I can't find it, sorry.
winjenkins
25
Aug 1, 2020 03:28 PM
WVJagXJLSC
Jul 3, 2016 08:38 PM
winjenkins
Apr 1, 2013 12:41 PM
Frog
Jan 15, 2013 10:27 AM
ChrisSTR
25
May 10, 2011 06:50 PM
