Want to replace headlamp assembly
Old May 6, 2014 | 11:57 AM
cadno's Avatar
Default Want to replace headlamp assembly
Right (passenger) headlight has heat damage to the reflector and connections so I need to swap it out. OEM replacements cost about $1000 and would not match the other side anyway. I have left several inquiries with salvage yards but with no luck. Any suggestions? The part number is C2C22619.
Old May 6, 2014 | 03:34 PM
H20boy's Avatar
keep watching ebay, you'll eventually find one.
Reuse your existing 'lenses'?
2004 2009 Jaguar XJ8 Vanden Plas Right Factory Headlight 04 05 06 07 08 09 | eBay
Contact this ebay seller directly to see if the entire headlamp is available?
04 05 06 Jaguar XJ8 Wash Reservoir Assy w O Headlamp Washers | eBay
Old May 6, 2014 | 05:12 PM
Brutal's Avatar
Damn and i have a drivers hid unit
Old May 6, 2014 | 06:43 PM
cadno's Avatar
Thanks for the suggestions so far. Should have clarified, my headlights are halogen not HID.
Thanks.
Old Aug 26, 2014 | 08:40 PM
04JagXJ8's Avatar
I have the same problem with mine. I have halogens too. Any luck finding a replacement?
Old Aug 28, 2014 | 01:48 PM
cadno's Avatar
I did find a replacement on ebay, had to wait a long time though!
Old Aug 15, 2015 | 11:54 AM
divingmom's Avatar
Default 2005 XKR Headlamp
The glass was broken on my LH headlight.
I got 2 quotes from body shops, both wanted $700-$800 to replace/labor.
I found one (OEM) on Parts Geek for $265 . Went to a different body shop, they installed for $50.
2005 XKR Convertible
Old Aug 15, 2015 | 01:08 PM
Don B's Avatar
Hi divingmom,
Welcome to the Jaguar Forums! It's great to have you with us. When you get a chance, please visit the New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum and post an introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers!
Don
Old Aug 15, 2015 | 06:02 PM
meirion1's Avatar
One here:
Jaguar X350/XJ Front Right Hand Headlamp Assembly. Good condition. Operational. | eBay
Forcedair1
Sep 8, 2025 01:57 PM
cissdm
May 3, 2016 06:02 AM
KarimPA
Sep 3, 2015 07:32 PM
innzane
Sep 2, 2015 10:08 AM
TC Johnson
Sep 2, 2015 09:30 AM
