water pump replacement - is there an o-ring?
Old 02-16-2019, 09:18 PM
Mark in Maine's Avatar
Come on you two. Which is best? 45 or 90 degrees?
John you said that 90 seems too much. How far did you go?
Mark
Old 02-17-2019, 04:14 AM
Received 1,423 Likes on 1,066 Posts
Mark
Mark,
For me when I attempted to go 90 degrees it felt too tight and didn't want to break any of the bolts so I personally settled for about 45 degrees. No issues.
Don B (02-19-2019)
Old 02-17-2019, 06:29 AM
jackra_1's Avatar
Received 1,755 Likes on 1,326 Posts
+1 on abonano's suggestion.
When I reached about 40 - 45 degrees, after the 8Nm setting, I could "feel" that it got a good deal harder to turn and was not going to risk stripping threads.
No leak issues at all with my single piece water pump.
Don B (02-19-2019)
Old 02-17-2019, 10:19 PM
Thanks guys. Are the water pump bolts ytt (stretch) bolts? Usually YTT bolts are stretch, and need to be replaced every time. Or are they just standard bolts that use a YTT spec for correct installation?
Mark
Old 02-20-2019, 09:10 AM
annamiata's Avatar
I just replaced water pump last week on my 2004. I got a water pump from Rock Auto with aluminium plate gasket. It was a shock to me that the water pump was previously replaced by Jaguar dealer ( shown on car fax when I bought it) and they used black paste silicon gasket and paper gasket. They put too much paste which caused the paste to spread and blocked at least 50% of the inlet and outlet of the water pump.
A C Delco Professional #252-800
Old 02-20-2019, 04:04 PM
I've used the AC Delco version in one of my older Jags. Good quality, zero issues. Good alternative to OEM.
Busa196
07-10-2019 07:22 AM
Dan R
03-31-2018 10:28 AM
QuikCat
07-28-2014 03:12 PM
Quick Reply: water pump replacement - is there an o-ring?
