What did you do to your X350/X358 today?
Old Mar 28, 2018 | 05:48 PM
  #481
romroc's Avatar
Originally Posted by NightHawk
Doesn't everyone love when recent repairs fail? I know I do... I got around to doing some replacing of my front suspension parts when trying to hunt down a very annoying creak last July. Replaced both front curved control arms with MAS auto parts, as the driver side hydra bush had failed 100%. No change in the noise. Fast forward to mid October when I had my indie do the air shock bushing on the driver side, and voila! Noise is gone.
Short lived that was, within 2000km the noise had begun to return. The other day it got Really bad coming home, so I stuck my head in underneath to see what is going on and..
Both failed. Luckily I have a second 101-7517 Beck/Arnley but it makes me wonder if I should get a different bushing considering this one didn't even make it 5000km. I am attempting to contact both MAS auto and Beck/Arnley about warranty replacement especially considering how they toot their horns about "OE Quality"
So, after all the ranting I have a question. Seeing as the bushings are already destroyed, would silicone spray lubricant shot inside of them at least make them slightly quieter until I can replace them again?
​​​​​​I will be trying to keep the driving to a minimum although I'm not sure if it's making a huge difference at this point
I like WD40 Rust penetrant. Heavy enough, easy applicator, use every month, see if it helps.
Old Mar 31, 2018 | 05:55 PM
  #482
jackra_1's Avatar
Finished replacing the last two of 4 pulleys to try and stop an annoying squeak.
The alternator is new so that really counts as 5 pulleys replaced!
Had to take out the coolant reservoir for these last two.
AND I still had the squeak. However this time I could hear where it was coming from whereas before I could not.
It is coming from the pulley on the SC!!!! I have only done about 6,000 since that was rebuilt!
When I sprayed WD40 just behind the pulley the squeak stopped.
I left the drivers door window open and maybe that is why I have a completely flat battery?
Old Mar 31, 2018 | 06:56 PM
  #483
romroc's Avatar
try wd40 rust penetrant. It's magic.
Old Mar 31, 2018 | 07:08 PM
  #484
jackra_1's Avatar
I do have some so will try it.
The battery was not flat. My negative connection was loose!!
Old Apr 1, 2018 | 09:56 AM
  #485
TBoneous's Avatar
I had a new head liner put in and replaced a delaminating front windshield. I washed her up, drover her to the backyard an snapped this pic. Man! These are beautiful cars!
This is Abby at home in the Sonoma county wine country! Ain’t she pretty?
Attached Thumbnails What did you do to your X350/X358 today?-13749fb2-f2f2-4b2b-9ca5-8c27ef76e668.jpg
Old Apr 1, 2018 | 08:46 PM
  #486
romroc's Avatar
they are puurty and the specs are equally impressive
Old Apr 3, 2018 | 12:30 PM
  #487
stham's Avatar
Ive been slowly collecting the equipment needed to properly scan & reflash modules on my XJR with the JLR SDD. I finally got the last few pieces (wire, clamps and a GOOD power supply) all within a nifty budget.
I adjusted ride height on all 4 corners, the heights were surprisingly all wonky. Here's the final result, im very pleased.
I dont get how some people can hate on this air suspension!
Old Apr 3, 2018 | 12:41 PM
  #488
jackra_1's Avatar
Squeak gone!
After replacing 4 pulleys I still had an annoying squeak. It went away when I sprayed behind the SC pulley.
So called PSE, who rebuilt the SC, and low and behold they no longer exist having sold their assets to another company.
So much for my 3 year warranty!
Spoke to Ed, at this new company, and he persuaded me that it was the belt causing the "chirp".
So today I replaced the SC belt which was new 6,000 miles ago.
No more "chirp".
While I have the radiator shield off I will de-rust the crossmember.
It is not that bad at all but I might as well while I can get at it.
Old Apr 3, 2018 | 02:25 PM
  #489
romroc's Avatar
I like it, its very comfy yet tactile over the road.
Old Apr 3, 2018 | 03:14 PM
  #490
Wingrider's Avatar
Smile
Love turns to hate, then back, when things get back to normal, lots of times, on all sorts of things.
Old Apr 3, 2018 | 04:28 PM
  #491
ayavner's Avatar
Replaced the coolant tank cap. Shortly thereafter observed a Check Engine Light... not sure the 2 are related, but looks like another rabbit hole to go down...
New rotors and pads for the rear arrived today though, looking forward to getting those on!
Old Apr 19, 2018 | 12:06 PM
  #492
jackra_1's Avatar
Took my back seats out ready for a 450 mile trip up to Cape Cod.
I can load more "stuff" to take and without damaging the seats. Most "stuff" will stay up there but tools will make the round trip.
I also take out the floor in the trunk over the spare wheel out. I can get several standard storage bins in then.
Also installing a "ski hatch" so will try and finish that job that I started months ago.
Old Apr 21, 2018 | 07:58 PM
  #493
abonano's Avatar
Dropped the rear bumper to replace a wonky reverse parking sensor. Surprised in the end how simple it was to drop it.
4 bolts behind the plastic trunk retainer, 4 plastic screw rivets under side and the 2 bolts under the rear wheel liner then pull out/back each side.
Applied anti seize to the bolt that reside under the rear wheel liner - each side, applied dielectric grease to each rear parking sensor connection, ensured all connectors were fully seated and cleaned things up before reinstalling the rear bumper assembly.
Now, time to troubleshoot an inoperative aux cooling pump.
Old Apr 22, 2018 | 09:42 AM
  #494
PeteK812's Avatar
Hey, jackra_1, how about some photos and a description of the ski-hatch project?
Old Apr 22, 2018 | 10:15 AM
  #495
jackra_1's Avatar
Default Ski hatch project
Some pics as requested.
Spent a lot of time trying to figure out how to install the whole ski hatch from some other car.
Ended up just modifying the swing hatch itself to attach to a metal bar in the rear seat.
It does not lock because of that however serves the purpose I had in mind for fishing rods.
I used a white pull strap to stop the hatch swinging back into the trunk.
It is a "tight fit" so it will not swing forward without pulling.
Note the plate that was originally in place over the hole. Just drilled out pop rivets to remove that.
Attached Thumbnails What did you do to your X350/X358 today?-p1000136.jpg   What did you do to your X350/X358 today?-p1000135.jpg   What did you do to your X350/X358 today?-p1000134.jpg   What did you do to your X350/X358 today?-p1000133.jpg   What did you do to your X350/X358 today?-p1000132.jpg
Old Apr 22, 2018 | 10:28 AM
  #496
Boomer from Boston's Avatar
To abonano re reverse parking sensor:
When you removed/loosened the various fasteners holding the rear bumper on, how did you keep it from falling to the floor? Did you leave it hanging by the sensor wiring?
Old Apr 22, 2018 | 11:36 AM
  #497
jackra_1's Avatar
When I took my front bumper off I used several of those see through crates to support the bumper as it came off and then disconnected the wiring loom connector.
I would do the same on the rear if I had to take it off.
Old Apr 22, 2018 | 12:34 PM
  #498
X358XJR's Avatar
Default Window Seal
Sorted out window seal by driver's door mirror. Had been incorrectly seated at some point in the past, been meaning to do for a while, but only remember about it when travelling at motorway speeds and getting wind howl. Only took five minutes to fix. Not sitting quite right due to being in the wrong position for so long.
What did you do to your X350/X358 today?-img_0324.jpg
Old Apr 22, 2018 | 05:04 PM
  #499
Fraser Mitchell's Avatar
Well actually it was yesterday !
Decided that as winter seemed in retreat, it was time to replace my Jaguar wheel centre badges. These start nice and shiny, but every winter they get tarnished and look bad. Polishing doesn't really work. I tried a bit of chrome cleaner, but ended up wearing away the paint without any improvement to the shine on the metal. I did this as being a bit of a Mean Sod, I would have liked the badges to last a bit longer.
Anyway, grubbed around in the garage and found the set I had bought last year still in their packets, put them on, and threw the old ones in the bin. I use cheap lookalikes made in Italy that are so cheap it's worth just replacing every year.
Of course then the chrome valve stem covers and caps looked really doggy now, so again grubbed around and found some new chrome stem covers. The caps polished up fairly well, but two of the Jaguars on the end have disappeared so come Monday, I'll be on eBay looking for a new set.
Incidentally, since I fitted the 17" wheels with fat tyres in autumn last year, all kerbing problems have disappeared and the wheels are still pristine.
Old Apr 22, 2018 | 08:46 PM
  #500
abonano's Avatar
No, I had help once it was time to actually remove the rear bumper.
Rested it on a single step ladder while handling the sensor swap.
