Wrong module?
Old Jun 8, 2023 | 11:49 AM
XJR_hunter's Avatar
Default Wrong module?
My CDC on my 2004 X350 XJR isn't working. Pressing the CDC button does nothing. No beep, nothing on screen. The actual CD changer accepts the disc cartridge ok.
On investigation using the hidden diagnostics screen, it looks like my car is programmed ad NOT having a CDC. Or phone neither. That explains why it says 'phone not fitted' when it actually is.
I then noticed that it says X409 on part of the screen.
Has someone replaced a module with the wrong type? Can it be reprogramed correctly so my CDC and phone work again?
Thanks so much.
Old Jun 8, 2023 | 11:04 PM
paulz67's Avatar
Sounds more like a fiber optic harness issue to me. Did you add those modules later or was the car equipped that way? If you have nav, perhaps try unplugging the fiber lines from the DVD and try them on both CDC and the phone module.
Old Jun 9, 2023 | 08:14 AM
motorcarman's Avatar
Info for you.
File Type: pdf
Old Jun 10, 2023 | 04:30 AM
XJR_hunter's Avatar
Thanks for the info.
So the fact that the module has obviously came from an X-type doesn't make any difference?
Old Jun 10, 2023 | 09:47 AM
Aix's Avatar
Aix
Do all other members of your optical bus work?
This type of bus requires a specific order in which the devices have to be included in the loop, if one is not installed then there has to be a bridge on its position.
Maybe you plugged your CDC in at the wrong position? But I’m not sure how this would affect the function of the other devices.
The required order of devices can be found here somewhere in the forum, need to search. I remember I found it here when I added my BT phone module.
Old Jun 10, 2023 | 09:51 AM
XJR_hunter's Avatar
I haven't added or removed anything.
When I go into the hidden Misc menu it says my car doesn't have a phone or CD Changer fitted, and it thinks it's an X type instead of an XJR.
Old Jun 10, 2023 | 10:44 AM
Aix's Avatar
Aix
Ok, sorry, I interpreted that to ‚added a cdc and the car doesn’t recognize it‘ …
my personal experience with interchanging modules between different car models is limited to the BT phone module, which came from a later s-type and worked straight away in the bus of my XJ8.
has the cdc never worked? Or have you never tried before? Or did it suddenly stop working?
Old Jun 10, 2023 | 11:28 AM
XJR_hunter's Avatar
It's never worked. Neither has the built-in phone.
I'm trying to work out if the X409 module is
not seeing the CDC, or if it came from a car that didnt have those options fitted.
Can i reprogram this module to the car?
Old Jun 10, 2023 | 01:13 PM
Aix's Avatar
Aix
I haven’t tried to change anything there, but this video shows some submenus of the Jaguar nav system that may enable you to activate/deactivate individual components in the setting
worth a try
Old Jun 10, 2023 | 01:25 PM
XJR_hunter's Avatar
That's the hidden menu I mentioned previously.
It doesnt let you change anything.
Old Jun 11, 2023 | 01:11 AM
Aix's Avatar
Aix
Then probably only a Workshop experienced with classic Jaguar cars can help.
Some years ago I discussed a similar topic with Jaguar Classic here in Germany to reprogram modules to the VIN of my car. They said theoretically they can do this, but by their experience the reprogrammed modules often still were not accepted by the car.
As these car were among the first ones with exploding numbers of electronics and digitalization, all still rather immature, some of these programmings are difficult to access, also because the programmers of the time are probably all enjoying retirement by now and today‘s systems are different.
Old Jun 11, 2023 | 09:57 AM
XJR_hunter's Avatar
That's not an option.
All the mechanics will have the same software as me anyway.
psyo
Nov 1, 2021 09:45 PM
tmwsccsh
Nov 12, 2020 05:08 PM
caryshaw
Oct 29, 2017 05:17 AM
solostax
Feb 1, 2017 10:09 AM
Simon.h
May 5, 2013 08:26 AM
