X350 Valet unlocking
Old Aug 27, 2025 | 09:19 PM
Bob Hornby's Avatar
Default X350 Valet unlocking
I have accidently pressed the valet button. I have read the manual and posts here to unlock but still cannot open the boot or glove box. It happened once before to me but I cannot remember how I unlocked ti.
Old Aug 27, 2025 | 10:21 PM
mjcarch's Avatar
You tried the main key to manually unlock the boot? That is supposed to cancel the valet mode lockdown.
Old Aug 28, 2025 | 05:58 AM
nebelfuerst's Avatar
valet locks trunk and glove box.
So if you can open the trunk, valet is not active.
Valet should disappear when pressing the fob-buttons on the main keys.
Old Aug 30, 2025 | 02:14 AM
Bob Hornby's Avatar
I have tried opening the boot with the key but no luck.
Old Aug 30, 2025 | 02:56 PM
Pete M's Avatar
Hi Bob,
Is there any chance that the key you are using is a Valet key? I think the valet key (I don't have one) is missing the pointed tip.
The mechanical boot lock is often sticky through lack of use. Try some WD-40 or similar in the keyhole, then try to exercise the key through full range of movement.
Also, try pushing down on the boot lid as you turn the key.
I agree with the other posters, using the fob to lock and unlock the doors should cancel valet mode.
Pete M
Old Sep 3, 2025 | 08:20 PM
Bob Hornby's Avatar
I have eventually fixed my problem. I pulled apart my key fob to check the battery and replaced it with a new one. Now I inserted the key into the boot lock and pressed the button on the boot at the same time and it unlocked.
Old Sep 3, 2025 | 08:23 PM
mjcarch's Avatar
Huge success and congrats.....I bet you feel fantastic.
loulizjag
Feb 13, 2025 09:14 AM
Mark99
Oct 15, 2016 02:38 AM
doc4141
Mar 4, 2015 05:45 PM
swampy
Nov 16, 2010 03:41 PM
tgds932001
May 19, 2010 02:04 PM
