advice needed
Old Jul 13, 2012 | 06:36 AM
kentmere's Avatar
Talking advice needed
Hello,
I own an X300, 1994. I have been told by the MOT inspector that one of the rear wheel bearings has too much play in it.
Is this bearing a taper bearing that can be adjusted or a roller bearing that needs to be replaced?
Old Jul 13, 2012 | 07:18 AM
Fraser Mitchell's Avatar
YOu'd be better off posting this in the X300 forum, as you're likely to get X300 experts with detailed knowledge give the info. AFAIK, however, they're ball bearings set up with about 2 thou of play. There must be play to ensure the things dont wear out prematurely. Excessive play means they are probably worn out. Adjusting the play is almost as much work as replacing the bearings, as it's not dome from the fron, so you have to remove the drive shaft to get at the spacer.
Old Jul 13, 2012 | 07:19 AM
Welcome to the forum,
Sorry to hear about the MoT. Is it a Failure or an Advisory?
Depending on how fast you need to fix this, options are rebuild or exchange. There's a company in Colchester offers
an exchange service.
Last edited by GGG; Jul 13, 2012 at 07:26 AM. Reason: remove link - thread moved from General Tech to X300
Old Jul 13, 2012 | 08:13 AM
Doug's Avatar
Originally Posted by kentmere
Hello,
Each rear hub has two opposing tapered bearing with a spacer between. Various thickness shims between the spacer and one of the bearings are used for adjustment. So....disassembly is required to change the shim and take up the slack. If there's any doubt as to the condition of the bearings it makes sense to replace them. They're probably worn
The spec is for a couple thou *preload*.
Old Jul 14, 2012 | 01:07 PM
kentmere's Avatar
Talking
Thanks to those three great guys that replied, I can see that this works so I'm glad to be here!!
Does anyone know how to do this work, remove the rear wheel bearings, how do I start?
Do I remove the big nut in the middle, dismantle the drive shaft. I'm not a complete idiot I just haven't got a manual on this car.
Can anyone help?
Old Jul 14, 2012 | 01:52 PM
If no one posts who already has the rear hub manual section available as a PDF or a doc, I'll load up my X300 CD and extract it for you.
Old Jul 14, 2012 | 04:07 PM
Doug's Avatar
Can anyone help?
If you go to the top of the X300 section there's a quick link section where you'll find the service manual download
Old Jul 14, 2012 | 05:36 PM
Be aware in case you have a slow connection - it's around 200mB.
Old Jul 15, 2012 | 06:23 PM
Derek,
I've replied to your PM with links to the docs you need.
philwarner
Oct 4, 2024 01:37 PM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
innzane
Sep 2, 2015 10:08 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
