Center vent removal
Old Apr 19, 2014 | 11:43 AM
JTsmks's Avatar
Default Center vent removal
Is this as easy as just pulling it out? Searched the archives with no luck. Somethings making noise in there when going over bumps and I'd like to pull it and have a look but don't want to "force the issue" and break something. Figured someone here has been there before me. Thanks
Old Apr 19, 2014 | 11:45 AM
Time-Pilot's Avatar
It just pops out as you suspected. I used a plastic blade screwdriver on the corners to ease it out.
Old Apr 19, 2014 | 12:24 PM
Don B's Avatar
JTsmks,
I don't know how similar our '93 XJ40 may be to your '97, but below is a link to photos I took of the process in our car. I hope they're helpful.
Welcome to Jag-lovers - Members Photo Viewing Page
Cheers,
Don
Old Apr 19, 2014 | 02:01 PM
aholbro1's Avatar
Spring clips on both upper corners, perhaps on lowers, too, but I can't remember. Not that similar to the XJ40 as the louvers and wood are all pinned together as one assy.
Thought I had some pics but can't find 'em. Will go have a gander about the shop and if the old piece is easily located, I'll snap you a few.
Old Apr 19, 2014 | 03:46 PM
motorcarman's Avatar
TSB 14-01 tells you all you need.
bob gauff
Old Apr 19, 2014 | 04:01 PM
Don B's Avatar
bob gauff
Bob,
That's so helpful, since all of us just happen to have one of those handy-dandy tools in our kits! :-)]
Looks like you could duplicate the function with a pair of right-angle solder picks, crochet hooks, or maybe even a couple of long thin screws with their heads inserted first?
Cheers,
Don
Old Apr 19, 2014 | 04:08 PM
JTsmks's Avatar
Originally Posted by Don B
Bob, That's so helpful, since all of us just happen to have one of those handy-dandy tools in our kits! :-)] Looks like you could duplicate the function with a pair of right-angle solder picks, crochet hooks, or maybe even a couple of long thin screws with their heads inserted first? Cheers, Don
Yeah I've got those things lying about everywhere, I was wondering what they were for!
Old Apr 19, 2014 | 05:13 PM
BigBossRadio's Avatar
Hi Everyone
Now we know how to do it correctly....... On the tool side I'm sure we can innovate..
BigBoss in Dallas TX
Old May 21, 2014 | 09:52 PM
al_roethlisberger's Avatar
I've got the same rattle in my center vent, and one or two of the "vanes" on the right side of the assembly no longer move/adjust in sync with the other vanes. So I suspect they have broken off the mechanism, and that may be what is rattling.
Did you find your rattling problem after pulling the vent?
Did you rig up something to pull the vent out? I bet a piece of wire coat hanger bent into a "U" with hooks would do the trick. I made a similar tool for Mazda Miata vents to pull them from the dash.
Old May 22, 2014 | 01:58 AM
jagent's Avatar
Use 2 pairs of long nose pliers. Tightly grip the centre horizontal vane in each vent. Pull & jiggle slowly and firmly, it's a tight fitting but it will come out. I've had mine out a couple of times using this method.
Old Mar 5, 2021 | 03:08 PM
Shuggyx's Avatar
Smile Also works for outer vents
Thank you so much for this. I'd spent hours on forums trying to find out how to remove the outer vents, and it tunrs out all you need to do is pull them out with long pliers (and out comes the fascia panel, too). I was all geared up to remove the under-dash panel and end-panel - thanks to you I've fitted my replacement vent in less than 2 minutes.
afterburner1
May 12, 2020 11:09 PM
Hoosier XK8
May 22, 2017 04:04 PM
al_roethlisberger
Nov 16, 2014 09:32 PM
supra-raleigh
XJ40 ( XJ81 )
Oct 13, 2014 03:47 PM
warrjon
May 8, 2013 07:58 AM
